2021 tail lights assembly upgrade
akout
kuwait
Did it need reprogramming of sort ? Ir was it plug and play ? Other than the wire slice of course
DWs-TTEB
Evans, GA
unless you like hyperfalsh telling you that you have a light bulb out, yes ForScan mods would be needed. Very easy to do.
Amamas2010
KSA
It doesn't need cut wire
You could use spical connectors to make it
I now some one make it in KSA
You can see the final result at his Instagram or tiktok
@prog_legend
He made a big facelift from XLT to Platinum
2021max
I had to reposition the cables and now I have hyperflasing problems since I could not find the correct codes for the FordScam
Jay Dubs
CT
Is there a cheaper place to get these? A junkyard or something.
mseymour67
Columbus, OH
I realize this is an older thread, but what did you have to do to the wires to get this to work? Do you have pics of the wiring?
Thanks
