Side Mirror Puddle Lights Recommendation, Easy Upgrade
18MaxLimited
US
It may be not as necessary to others but it gives a noticeable difference, plus it's so easy you'll never look back. Lighting and cohesive color temperature for me, is important. I did this on both our previous Max Limited to color match lights after retrofitting OEM LED headlights, and again with our current Max Platinum.
Not sure why Ford upgrades all the lights on higher trims but leave these out. Below, is a quick before and after comparison and what I used.
All you need is about 10 minutes time, a flathead screwdriver, needle nose pliers and electrical tape. No other special tools needed.
Lights I used bought off Amazon:
Easy Eagle Full LED Side. https://www.amazon.com/dp/B07RWB34YC?ref=ppx_pop_mob_ap_share
Stock light on the left and new LED light on the right with longer connecting wires.
Before:
After:
Ideally, you should disconnect your battery but I didn't and just kept the wires separate making sure not to cross wires.
1. Use a flat head screwdriver to gently pry the light out of the bottom of the side mirror and tilt the other side clip out.
2. Gently pull the light and wires out and disconnect the negative wire. You may need to use the needle nose pliers to separate the connection here so that you don't pull the wire.
3. With the OEM light hanging, connect the negative wire to the new LED light. The metal connection is exposed on the new LED light so wrapped it with some electrical tape to prevent short.
4. Repeat the same with the yellow wire.
5. Reinsert the light and repeat on the other side.
It was simple enough and just thought I'd share.
Anerbe
Mi
I feel the same way with the license plate lights. Actually parked next to two other expeditions. We all had ours on remote start, and they commented how nice LED white license plate lights look on mine in comparison to the dull yellow.
TheDoug
Mansfield, TX
The new model puddle lights are led from ford. Just ordered those and put them in. Didn't want to go aftermarket.
I did go aftermarket for the led license plate light though.
Love the way they look vs yellow dull lights
Anerbe
Mi
just look up the part on the ford parts website as a 2021 model to get the LED lights?
Oklahoma Jim
Looking forward to the Ford part number. I haven't found them on the Ford site yet.
bryz_expy
Denver, CO
My 19 Platinum has LED (5000k temp) puddle lights. OP I think maybe certain years or certain trims include them already? License plate bulbs were incandescent (yellow) and Inseapped those.
TheDoug
Mansfield, TX
You are correct 18s didn't have leds stock. Then in 19 or 20 the made them all leds.
They look so much better than the old ones
Anthony DeVor
I bought the dorman aftermarket lamps but am now having an issue in my BCM. I have a 3rd Gen Expy (2017) and my Bdycm is throwing a couple codes and shows that the circuit is shorted to ground - it is only putting out 1.2v on the puddle lamp wire. So beware of the aftermarket puddle lamps. Granted the puddle lamps still works but the Bdycm puddle lamp circuit died so I don't know if it is an internal issue or if it is the puddle lamps causing an issue.
Oklahoma Jim
Wow! My local dealer wants $43 each for the Ford LED puddle lights! I'll try the ones the OP suggested.
Going_Going_Gone
Phoenix
Has anyone attempted to swap out their puddle lights for the SVO lights used in the Raptor? Same brightness, more cool factor.
blackedoutlimited
United States
Before:
After:
Looks great. I did drive bright bright trax. $50 for puddle lamps and license plate bulbs. 5 minute install and really lights up the ground
