Hellwig Front Bushing Replacement
KFordEx8
SF Bay Area
It didn't take long for a clunking noise to start after the front OEM bar was replaced with the Hellwig unit. Got worse as time went by.
Ordered Prothane part no. 191505 from suspension.com and replaced them today. Didn't hear any clunking with a short test drive.
The Prothane bushings are slightly larger; included metal brackets are thinner. They are also a better fit because the bracket holes are smaller.
maxxplatinum9137
Washington
Why did you get a hellwig to begin with? What are advantages over OEM?
DWs-TTEB
Evans, GA
well documented in these threads:
BMW2FORD
CT
The thicker tighter sway bar bushing and bracket will be better to help the cause of better handling but for sure noise can be a problem. This is a generic picture but you might have to find bushings with a grease fitting or what I’ve done on a lot of cars is drill a hole with them removed, tap it and add one.
Energy Suspension 9.5165R 1-1/4" Greasable Sway Bar Set https://www.amazon.com/dp/B000CN7C1...t_i_010GQZQN879J2R9GGVV5?_encoding=UTF8&psc=1
K
KFordEx8
SF Bay Area
I wasn’t able to find a 1.5” with a grease fitting. When it starts squeaking and I can’t stand it, I’ll mod it with a fitting.
wakeboarder
Fort Lauderdale, FL
Is the rubber split or do you have to completely remove the bar to install them?
K
KFordEx8
SF Bay Area
The bushings are split so just have to pull each open to slip around the bar. I used a heat gun on low to warm them up so they would spread easier. Another way is to make them more flexible is to warm them in hot water.
Went for a longer drive and noticed an improvement over the Hellwig units. I think the Hellwig bushings are softer. That along with the play that developed that caused the clunking made the front end more sloppy.
TheDoug
Mansfield, TX
Was the clunking noise you are describing occuring when you turned or when there was a bump im road while going straight? Thanks, i got some noise from mine and wonder if this will fix issue.
5280tunage
colorado
Same, I have a small clunk when turning. Sounds more like steering vs. sway.
TheDoug
Mansfield, TX
I think mine may be related to skid plate not 100 percent lined up and tightened down then. When it gets back from dealer i will have to investigation further
Thanks for info
MUSTAFA4072
