Oil Catch Can Question
RockyRob
I have a 2016 Exp Platinum, 86k miles. I added an oil catch can from Amazon, it has a 3 oz can.
I drove 250 miles and the check engine light came on. I checked the can and it was full. Emptied it and bought a 3 oz extension for the can.
It has been cold, below 20 degrees when I drove it, some snow when the can filled up.
Now I am very hesitant to even drive for fear it will fill so quickly and will become a total pain for me.
I might be able to get 4-500 miles between, but I read threads where people are emptying it at each oil change.
Is it possible it was because of the weather or do I have other issues?
Should I remove it and put the original hose back on?
Moderator
What brand can?
Moderator
OK, most likely due to the cold. Do you remote start it or let it idle a lot? Won't hurt anything if it fills up. Just does what it was doing without it and going in to the inake.
Next time you empty it, post a picture of what it caught in a clear container from the side after it has sat for a few minutes. I am looking for layers.
Alwaysthinkin
Georgia
I hope you aren't using these weight oils in your vehicle.
I do not. My personal choice has been Castrol Edge Full Synthetic 5W-30. However, I have read a surprising number of posts where people are using a different weight oil then recommended by manufacturer. That was reason for my question.
JasonH
Houston, TX
You can get an AOS and eliminate the need to empty the can.
Moderator
Air Oil Separator.
I think you are slightly confused. An air oil separator is what we are calling a catch can. It separates oil from the hot EGR air, and captures it in the catch can. Are you talking about a breather? Which is a issue on our modern closed system.
JasonH
Houston, TX
The AOS does the same thing as the catch can, but also drains back to the oil pan. No dumping necessary.
Moderator
By definition, not all air oil separators do that. None of the catch can setups out there for these platforms currently do that. Even UPR's VERY expensive setup doesn't.
Also, these catch cans ARE Air Oil Seperators. You are talking about a specific type of Air Oil separator that drains. Also, you would have to filter it even further to drain, because a lot of what is caught is moisture. Wouldn't want to intentionally add water to your oil.
JasonH
Houston, TX
Thanks for clarifying. I guess it's like a square being specific type of rectangle. When I first purchased the vehicle and read about the catch cans, I wondered why they didn't drain back to the oil pan. When I googled it, the search came back with the AOS. So I figured that was the difference between the two. I think the water draining back would evaporate at operating temperature? Especially since it wouldn't have an opportunity to accumulate if the vehicle is driven regularly.
I hate to admit it because I do most of my own maintenance and minor repairs, but I hate popping the hood on my Expedition. It's a rat's nest in there, and the vehicle is very tall. The thought of having to drain a catch can repeatedly is anathema to me.
Moderator
Common misconceptions.
Water does not evaporate when mixed with oil quickly at all especially when in a closed system like a motor. With it being churned and pumped it stays in suspension, and dilutes the oil, and it can cause hotspots and generally decrease the good properties of the oil.
If allowed to sit, the water actually goes to the bottom, with oil on top. That prevents the water from being able to come in contact with the air and evaporate.
The Catch Can is a piece of cake. Unscrew, empty, screw back on.
R
RockyRob
I get all oil changes done at Ford Motor Co with synthetic blend. I will tale a picture soon. We don't drive it much since we use the car with netter mileage.
When I emptied it,, it looked like coffee with milk in it. Very watery.
Moderator
Perfect. You are welcome to post a picture, but it is due to the cold. Do you idle a fair amount? That will typically cause it to collect more moisture.
