Oil Catch Can Question
RockyRob
I have a 2016 Exp Platinum, 86k miles. I added an oil catch can from Amazon, it has a 3 oz can.
I drove 250 miles and the check engine light came on. I checked the can and it was full. Emptied it and bought a 3 oz extension for the can.
It has been cold, below 20 degrees when I drove it, some snow when the can filled up.
Now I am very hesitant to even drive for fear it will fill so quickly and will become a total pain for me.
I might be able to get 4-500 miles between, but I read threads where people are emptying it at each oil change.
Is it possible it was because of the weather or do I have other issues?
Should I remove it and put the original hose back on?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
What brand can?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
OK, most likely due to the cold. Do you remote start it or let it idle a lot? Won't hurt anything if it fills up. Just does what it was doing without it and going in to the inake.
Next time you empty it, post a picture of what it caught in a clear container from the side after it has sat for a few minutes. I am looking for layers.
Alwaysthinkin
Georgia
I hope you aren't using these weight oils in your vehicle.
I do not. My personal choice has been Castrol Edge Full Synthetic 5W-30. However, I have read a surprising number of posts where people are using a different weight oil then recommended by manufacturer. That was reason for my question.
JasonH
Houston, TX
You can get an AOS and eliminate the need to empty the can.
