dan2jen
purchased a 2018 exp max xlt w/ 140k miles on it in Mid Feb 2022. Got a good deal because of the high mileage and the car looked to be in pristine condition. Quickly found out it has the cam phaser issue and had check engine light on and was told that the cat converter needed to be replaced. Local ford place (Abilene, TX) quoted me just over $5k (including labor) for the cam phaser Repair and $1900 for the cat conv (parts only, no labor). I was advised to shop it around because any place that does the repair *should* use the Ford OEM parts, so cost would be about the same but labor rates would probably be half of what ford was charging. So I got several recommendations to a good local shop and they are able to fix cam phasers AND the cat converter (custom fabricated, instead of OEM replacement part) for $4500 (parts AND labor). Just dropped it off today and should have it back in a couple days. I’m crossing my fingers the repair is successful and that not going thru Ford doesn’t screw me Later. Just sharing this in case in others might be in a similar situation. I’ll try to update once repairs are done. Oh… and they are also going to try and do the Ford TSB SSM47713 for the mirror clicking as well.
