Cam Phaser and Cat Conv Replaced
dan2jen
Abilene, TX
purchased a 2018 exp max xlt w/ 140k miles on it in Mid Feb 2022. Got a good deal because of the high mileage and the car looked to be in pristine condition. Quickly found out it has the cam phaser issue and had check engine light on and was told that the cat converter needed to be replaced. Local ford place (Abilene, TX) quoted me just over $5k (including labor) for the cam phaser Repair and $1900 for the cat conv (parts only, no labor). I was advised to shop it around because any place that does the repair *should* use the Ford OEM parts, so cost would be about the same but labor rates would probably be half of what ford was charging. So I got several recommendations to a good local shop and they are able to fix cam phasers AND the cat converter (custom fabricated, instead of OEM replacement part) for $4500 (parts AND labor). Just dropped it off today and should have it back in a couple days. I’m crossing my fingers the repair is successful and that not going thru Ford doesn’t screw me Later. Just sharing this in case in others might be in a similar situation. I’ll try to update once repairs are done. Oh… and they are also going to try and do the Ford TSB SSM47713 for the mirror clicking as well.
maxlim2022
Illinois
ouch! hefty start to ownership. I hope things are definitively addressed during the repairs. Please keep us appraised
Soliyou
OK
Thanks for posting. one question, At this mileage, I am interested to know if you had experienced any drivability issues with the camphasers rattling. Was the check engine light also related to cams? Or just the cat??
Ford claims that the rattle has no effect on reliability, but we are not sure about this!
D
dan2jen
Abilene, TX
Obviously, I’ve only had it a few weeks, but it seems to drive fine. I hear a bad rattle for 1-2 seconds at start up (worst on first start of the day), but is almost not noticeable when driving. Originally my check engine light was related to cam phaser issue (according to ford) and they cleared it when they gave me the estimate for repair. Then about a week later it came back on and I had them read the code to make sure it wasn’t something else and that’s when i was told it was for the cat converter. The shop I ended up taking it to said they agreed that cam phasers and cat needed replaced.
D
dan2jen
Abilene, TX
Yeah, we paid just over $30k for it and the next cheapest I could find (locally) was at least $40k-45k and up. So even with $5k of repairs, I’m still $5-10k less than the next cheapest one and whose to say those won’t have the exact same issue. The joys of buying a used vehicle!
maxlim2022
Illinois
i hear you! Well, if this is the only major headache, then you are indeed ahead despite the costs.
Shaggy
Administrator Moderator
Arizona
I thought cam phasers where a recall issue, so bo matter the mileage, they were covered. No I'm not 100% sure but my 2018 Raptor has over 55k miles and I'm getting them replaced without being charged for it.
Bmac1955
Southern Cali
I believe there is a mileage warranty. After exceeding the mileage set by ford you are on your own.
AJ82
I believe it was a "customer satisfaction" thing and not officially a recall as it isn't safety related. There are mileage limits like Bmac stated.
blue_roster_cult
Missouri
I have 130k+ on my 2018. Fortunately, the cams have been repaired under warranty. My engine light graces us with its presence from time to time and according to the Ford App, it is emmissions related. I was *hoping* it was a simple o2 sensor repair. I can’t understand why the entire converter would need replaced at 140k. Interesting to know what could be on the horizon. Thanks for the heads up.
Soliyou
OK
Oil consumption and low quality fuel can cause catalytic converter issues. If not, then lowest price bid and cheap parts are to blame.
D
dan2jen
Abilene, TX
So, good news… got my expedition back on Friday. Cam phasers fixed and it sounds great! Mechanic also felt pretty confident a sensor they fixed related to the phasers was what was tripping the check engine light for the cat converter, so we did not have to do any repair. We can still hear a slight rattle when accelerating that sounds more like a loose part (missing/broken strap maybe??) on the cats. He’s gonna look closer next week, but the major issue seems to be fixed. $3800. FYI, when we initially scheduled the job he told me lots of the parts (he used all Ford parts) are backordered and have no ETA. We both figured it would be months, but it only took a couple weeks to get all the parts here.
S Mathieson
Canada
My 2018 Expedition was covered under a recall by Ford. As was my 2020 Navigator . Just saying.
bryz_expy
Denver, CO
I was told 2018’s there was a bad batch of cat converters. Despite that, my 2019 had the reprogram and the cam phasers repaired under warranty. 3 days after the repair the cat converter efficiency CEL showed up. This was early January. They reset the light once and then ordered the new parts. I go in 4/6/22 for the catalytic converter repair. I just hit 37k.
Regardless it’s 8/80k on emissions but sounds like OP was past that. Ford should provide some level of help in those cases. These vehicles sound like maintenance nightmares. I have the ford ESP until 100k but I’m not sure I will keep it that long.
I’m hoping they can also check out the front end. Have a rattle at slow speeds on first drive of the day that gets quiet as I drive. Sounds like a ball joint. Vibration in the pedal makes me think it’s the check valve for the front wheel actuators for AWD. Pedal vibration feels worse when set to AWD.
Hurricane
Ours had the cat converter replaced around 20k miles and an O2 replaced immediately after that. I’m inclined to think that a bad O2 sensor caused the cat failure due to wrong fuel/air mixture ratios.
JGolfer
Saint Joseph
I purchased two 2018 Expedition Max's with both with roughly 120,000 miles on them and at the time of purchase the 1-2 second rattle was present as well as a noticeable ticking at idle. It concerned me, but literally of the four I looked at all had the same sound. I had previously always owned GM Suburban's so wrote this off to inexperience with Ford. The one I have personally driven for the last 2 years and about 46,000 miles the startup knocking has increased (gotten worse) as well as the idle ticking. I've had guys in parking lots comment sounds like a diesel. Anyway I took it to the Ford dealer for the CSP's Cam Phasers Campaign #21N03 and PCM Reprogram Due To Engine Shudder Campaign #21N08 and it did not resolve the problem. The work order comments included the significant cam phaser rattle at startup.
Drivability was never an issue, but I was concerned about a failure and possibly significantly damaging something internal or worse having a safety issue on the road. I had four dealers as well as an independent shop quote the repair. I took the list of quoted parts and determined I could buy the OEM parts at at roughly 32% discount Ford dealer $1,264 vs online OEM $858.00. The book repair time was something like 12-15 hours so I figured it would take me a week and I'd need to buy or borrow a few tools. The dealer quotes ranged from $3,552 ($1,464 parts + $2K labor & tax) to $4,227 (parts, labor & tax stated they needed $2,400 down for parts to schedule). Also checked with an independent shop but they simply didn't have time for the job and never gave me a number but backing into it I figured they would have been $500 to $900 cheaper.
The advantage of doing it at the dealer is they are experienced at completing the work as they are doing multiple repairs per week. Also the repair comes with a 2 year unlimited mileage warranty. I figure that had a lot of value and it was worth paying for it to be done right although I would have loved to tear into this myself and learn a lot in the process.
I scheduled the work at the lower cost dealer who also had a courtesy car for my use which I took full advantage of. I also had them replace the water pump with new since it was leaking just enough to consume antifreeze but never show a drop on the ground as well as complete a tune up with plugs, boots etc. They also changed a belt and basically went over anything that made sense. The final bill cam (e no pun intended) out to $4,051.27.
The rattle is completely gone on startup with a quite idle. Just finished up a 2,500 mile trip and the only issue I'm seeing now is an engine shudder on light acceleration or at 1,200 rpm and 30 to 40 mph. If I manually shift down a gear the shudder disappears. So that is the next thing to ask the dealer about as this was not present before they did the CSP reprograms.
For those comments about warranty. Ford told me under 60K miles it was fully covered and then Fords contribution is reduced by 1/3 for every 10,000 miles over 69K with zero covered over 99K. I was well over that so 100% my ticket. Overall I'm not at all happy about that large of a repair bill, but the vehicle is great for road trips with mileage over 20 usually. Having driven two Suburban's over 300K and never having a big expense, it was a lot to swallow. Time will tell if I stick with Ford, but for now I'm happy to have completed the work.
fatgroundhog
OKC
We had the emissions CEL and Ford wanted to change one cat. Instead I replaced both cats…and still get the CEL from time to time. No drivability issues and it goes off by itself.
Thom
$30k for 4 yr old vehicle with 140k miles. Ouch. Times have changed haven't they?
NukeLife
Charlotte
You’re going to be even less happy when that rattle shows back up in a year.
