Shows 9,200 lbs max weight but need to know first hand experience. Thanks.
Is that 8K wet or dry? If it's wet you'll probably be ok with proper WDH setup provided you have the payload. If it's dry forget about it. My camper's GVWR is around 7,800, but it's ~7K loaded. If your camper is rated 8,000 GVWR, you may come in well under that loaded. Also, some campers naturally place more weight on the tongue, so you'll have to check the manufacturer spec for tongue weight, as well as a scale. Mine is a 33' ft ultralight, so it has some flimsier materials to keep the weight down. It pulls fine since I got the WDH dialed in. When it's windy I just reduce speed from 65 to 55 - 60 mph and it doesn't move so much. My vehicle is an EL, which is the previous generation equivalent of the Max.
Looks like the dry weight is 6303. You should be fine as long as the WDH gets dialed in right.Looks like I've been thrown in the deep end of the pool..sink or swim! Going pick up the camper next Wednesday. Talked to the salesman twice and gave him the specs on the Expedition and my concerns about towing that size trailer. Much to my amazement he said we should be OK. I'll roll the dice and see what it will do heading back home from the Lafayette area on US 90 one of the roughest roads in the world!
Safe travels! I suggest watching some videos on WDH setup. Don't trust the dealership. They'll put you on the road in any setup.Looks like I've been thrown in the deep end of the pool..sink or swim! Going pick up the camper next Wednesday. Talked to the salesman twice and gave him the specs on the Expedition and my concerns about towing that size trailer. Much to my amazement he said we should be OK. I'll roll the dice and see what it will do heading back home from the Lafayette area on US 90 one of the roughest roads in the world!
I watched a few that Equalizer posted per your advice. Thanks Jason. What area of Houston are you in Jason? Wifes sister lived in Kemah/League City.Safe travels! I suggest watching some videos on WDH setup. Don't trust the dealership. They'll put you on the road in any setup.
I made a number of trips to Florida with our 30 footer with a weight of 7300#, so with all the junk, I'm sure it was over 8#. I just set the cruise for about 65 to 70 and enjoyed the trip. Ours is a 2018 4WD and 3:70 gears. Still had a pretty good ride! Lots of academic answers, I con only speak to my experiences. I will say, I wouldn't want to do the Rockies with it.
Maximum towing capacity is not a planning number as it's based on a completely EMPTY tow vehicle. Expedition, F150, Silverado, they're based on the same formula. Every pound in excess of a 150 pound driver decreases the towing capacity.
Then there's tongue weight as mentioned above. Look at the data plate in your driver's door jam. A conventional trailer requires 10%-15% of its total weight to be on the ball. 920 to 1380. My total cargo/passenger capacity tops out at 1416 pounds.
Motorboat trailers only need 5%-10% on the ball.
My personal rule of thumb is the One Ton Rule which states the tow vehicle needs 2000 pounds (a ton) more towing capacity than the trailer weighs and vv for Happy Towing. This limits my Expedition to towing no more than 7200 pounds which puts at least 720 pounds on the ball and requires a WDH. I made up that "rule" and it's conservative but have been using it for years. 1000 Pound Rule is less satisfactory for me.
Would I tow a 9200 pound trailer across town? Sure, but not across the state.
-- Chuck
Great testimonials on the Expo's capability. I have a '21 Limited with max tow package towing a Lance 1985 TT. I live in the Rockies and have towed it for over 8000 miles. Scaled it twice to get the WDH dialed in. Our last 4500 mile trip we came in at 12,500 GCVW which is 82% of max capacity. However, my rear axle is at 96% and front axle at 88% of the respective GAWR so I wouldn't want to pull anything larger. The Lance has a 800 lb tongue. My trailer weight fully loaded is at 5850# (w/ 30% fresh water) and the Expo is at 6650 or 90% of the stated GVWR. It pulls great up any pass. The TT box is 19' and I really never felt wind gusts much at all. My only reservation is the 10.2 mpg we averaged on the trip and in the mountains we filled up with 91 octane as the low end regular up here is only at 85 octane which is below Ford's recommended 87 min level.
Our 7K TT with WDH drove great. ~20K miles towing or so including two big trips out west (Rockies in CO, WY, MT both times) and two trips down to FL from PA as well as a lot around the mid Atlantic region. As others have stated, the key is that good set-up dialed in with your WDH! Our TT came with a blue ox sway pro and I had it perfect. It did eat the two cats on the last big trip out west and we suffered a little with noise and like 5.5mpg from MT to PA... But, no power issues, just efficiency/emissions. Got an RV now, so mine now relegated to toad/bike rack duty...
The maximum allowable towing capacity is a relative term which in practice is hardly ever achieved, unless you have the right tires, weigh distributing hitch and only the driver and no cargo and trailer brake control. Towing anything near the limit with result in dangerous driving conditions that could lead to disastrous results.
Take a look at the linked video that explains in detail the process to determine the actual towing capacity. Keep in mind that if an accident happens and you are over the limit, your insurance company will not cover any damages or the corresponding liability.
What Can You ACTUALLY Tow? Payload -Tow Capacity - Travel Trailer
Check out my new in depth honest owner review of the Jeep Gladiator! https://youtu.be/fMOtcX1oXxoSUBSCRIBE TO MY NEW CHANNEL FOR MORE CONTENT LIKE THIShttps:...www.youtube.com
Get a smaller trailer. Besides so crowded now days the smaller you go the higher chance you’ll find a place to stay. Not to mention lower fuel burn and better range err lower pump costWife likes a Cougar 25 RDS that's close to 30' long and grosses out at over 8K pounds. Its supposed to be 1/2 ton towable but we all know how that goes. I don't know if my Expedition could handle it on our terrible roads in Louisiana. Our previous camper was a 41' Solitude 5th wheel and pulled by a '17 F350 dually. Camper was totaled in hurricane Ida and I sold my dually and bought the Expedition with no intentions of getting another camper. Wife misses camping with our friends so hopefully I can change her mind. Prices are too high on RV's and getting about 8 mpg on the hwy with the Expy with its 23 gallon tank doesn't thrill me. Miss our 5th wheel and dually even more!!
