Middle Roof Crossbar
jferg425
michigan
We are looking for the middle crossbar for our ‘21 max and can’t seem to find one. Can anyone help point us in the right direction? We are trying to put a cargo box on the top but pushing it back so you can still see out the moonroof-so we need the middle bar.
TheDoug
Mansfield, TX
My expedition came from the factory with 2 crossbars. I bought a Yakima skybox and it was too short to reach the front and back position. I just used at torx t35 (I think that was the size) and moved the crossbar to middle position.
Lou Hamilton
It is a Torx 27 (T27). I just installed the middle one. But I was told to use a T30. It was a bit too big. 27 seemed to work perfectly.
wakeboarder
Fort Lauderdale, FL
The middle and the rear use the same bar. JL1Z7855107AA
The bolts are pn W716332S450B. Might as wells keep the option to use all 3 bars at once.
I did the same thing so I could access the box from my rear bumper. Just be sure your box clears the rear wing when rear hatch is up.
Tom Smyth
MA.
Keep in mind max weirht/load including turle box is 125 lb. be safe and keep it at 100 lb
Jamaican Cruiser
Vienna, VA
I purchased a rear rack from the dealer and installed in the middle. Really helps with stability to the Roof carrier, as mine was flexing a bit.
2020ExpyPlatinum
Cleveland, OH
I moved the crossbars to the rear as others stated. When the holes don't line up in the cargo box i just drilled new holes in that matched the spacing with crossbars towards the rear.
