Adding skid plates to 2018 Limited with tow package?
JONWIC
Anyone try the plates from the new Timberline? I would think those would bolt right up since most the changes were just cosmetic
Elcid
North Carolina
Curious on the Timberline skid plate as well. I'm sitting in the dealership looking at one right now. Seems it would work but not certain.
kmart223
I need some help.... I've ordered everything on here for the factory FX4 stuff and the raptor tranny plate. The oil access part is not matching up at at all. The part number for the raptor plate was replaced with a C instead of an A.
My expedition is a 2020 Platinum Max, Did parts change from when you guys did this??
TheDoug
Mansfield, TX
Got a pic of what you received?
kmart223
Here is what I received. I took a couple photos, and one for fun since it basically is an FX4 package minus the shocks lol
kmart223
kmart223
Well after a lot of googling I figured out my oil access panel issue. For anyone doing this now the raptor transmission cover part changed slightly. It still fits perfectly; however, the oil access panel part is different than what is listed in this thread.
The part number is HL3Z-7222-D,
Attaching hardware is:
Bolt (3qty) W500623-S439
Nut (3qty) W520813-S439
TheDoug
Mansfield, TX
Here is the raptor skid plate on mine and the oil pan bolt access panel attached
kmart223
Well I finally got my oil change panel for the raptor skid plate, fits perfectly!
Underside of my Expedition is ready to go!
Now to start looking at upgrading the shocks….
DavidN
Houston, TX
So i have a 22 Limited Stealth (finally!), 3" lift, nittos. Not having a lot of luck finding anyone local (Katy, TX) that's willing to take a shot on the skid plates (including the dealer). Found this thread (thanks) and i think i might pull the trigger on some items. Do you guys have any suggestions?
Here's what i gather so far....
RCI 09-14 F150 Parts: https://rcimetalworks.com/product-category/ford/expedition-navigator/
Fill in the rest with OEM parts like these?
HL3Z-7222-A Under Cover $110.63 1 $110.63
HL3Z-7222-B Under Cover Access Panel $24.18 1 $24.18
JL1Z-5D032-A Skid Plate $50.67 1 $50.67
JL1Z-5D032-B Skid Plate $132.94 1 $132.94
JL1Z-7E063-A Plate $29.30 1 $29.30
JL1Z-9A147-A Skid Plate $78.86 1 $78.86
-W520813-S439 Damper U-Nut $1.44 4 $5.76
-W709390-S439 Damper Bolt $2.01 4 $8.04
-W704336-S439 Lower Bracket Bolt $1.44 10 $14.40
-W714338-S439 Fender Bolt $1.44 8 $11.52
-W716538-S450B Hinge Nut $1.44 8 $11.52
-W717461-S439 Skid Plate Nut $2.01 16 $32.16
-W505594-S440 Plate Bolt $2.59 6 $15.54
-W717268-S439 Sunroof Frame Screw $3.74 4 $14.96
-W717634-S439 Front Shield U-Nut $2.01 6 $12.06
JL1Z-9054-D Tank Strap $28.22 1 $28.22
JL1Z-9054-B Tank Strap $28.12 1 $28.12
acepilot13
Missouri
So I'm doing the 3 skid plate installs since I bought a used 2018 limited and it didn't have any protection under it. Was missing almost every cover. I will be making a YouTube video to show how to install it. Just coated all of the skid plates with iron about truck bed coating from harbor freight and am very happy with how they turned out. Will post a consolidated list for what you need if you have fasteners still in the frame.20230905_201926.jpg20230905_201935.jpg
KenK
Houston
DavidN, See my earlier posts about installing combination of RCI, Raptor, and OEM plates on my 2018.
I also live in the Katy area if you want to look at it.
Where are you seeing the parts prices? I still need to pick up the oil cover for the Raptor transmission skid plate but am seeing prices around $50 instead of $25.
BMW2FORD
CT
Thanks for the heads up. I got the HL3Z7222b access cover and ran into the same problem. I was tight on time and ended up elongating two of the holes and adding one to get the access cover to work. Wasn’t fun for the cost of that little panel by my local dealer parts person was pretty sure this was the only access panel he could get.
j5_taylor
Ca
So I'm doing the 3 skid plate installs since I bought a used 2018 limited and it didn't have any protection under it. Was missing almost every cover. I will be making a YouTube video to show how to install it. Just coated all of the skid plates with iron about truck bed coating from harbor freight and am very happy with how they turned out. Will post a consolidated list for what you need if you have fasteners still in the frame.View attachment 78707View attachment 78708
Ever make that video? Very bolt on/ very easy but always nice to watch it go in first to avoid mistakes.
j5_taylor
Ca
I also installed the front two skid plates that come standard on the FX4. As expected, no surprises since it's an OEM fitment. Photos and a parts list are attached. Roughly $250 in parts, brackets, and fasteners. I also painted everything with "Chassis Black" POR15 to help with corrosion in the salty winters.
View attachment 28534 View attachment 28536 View attachment 28537 View attachment 28538
Did you leave the front "fender apron" ?
acepilot13
Missouri
I did video it. I have not edited any of the raw video since I've had 2 kids since then haha. I'll see if I can find some time to get it together for you today.
Trainmaster
Old School Member
Rockaway Beach, NY
Just picked up the Fuel tank skid plate at Levittown Ford. The tank straps have to be changed also. The ones for the plate have studs mounted on them.
The Third Generation trucks had the same arrangement and the straps were easy to change on that truck. We'll see how this goes.
Kevin Baird
Virginia Beach
I spent a lot of time cross checking and below is the parts list I used for a 2020 Expedition Max Limited Stealth 4WD.
2020 Ford Expedition Max 4WD
Transmission skid plateRaptor
QuantityPart #Description
6​
W704336-S439Bolt10x30mm13mmhex1.5 thread
6​
*W717634*S439U Nut10mm 1.5 thread…13mm hex
1​
HL3Z*7222*Eskid plate
1​
HL3Z-7222-FOil cover
3​
W500623-S439boltM8x20mm hex
3​
W718396-S439nut spring
Transfer Case Skid Plate
4​
*W520813*S439NutM8-1.25 thread
4​
*W709390*S439BoltM8 x 25mm-1.25 thread11mm hex head
1​
JL1Z*7E063*APlate
Front skid plate assemblyFX4
1​
JL1Z-5D032-Bskid plate
1​
JL1Z-6G079-ABracket
1​
Jl1Z-6G079-BBracket
6​
W717461-S439U-NutM10x1.5
6​
