Some Issues Observed in XLT 2020 - Need Forum Opinion and Advice
AlterEgo
KSA
Hello,
First time owner of Expedition and have been happy with the purchase so far. I recently got 2020 XLT 202a package (leather interior, panoramic moon roof , power liftgate, minor other blings etc) as a second owner. The mileage is around 57K and under extended premium care warranty until 2025 (or 200,000KM). Any/all recalls listed so far are already applied by the previous owner.
After almost 2 months of usage I have some observations / recurrent issues for which I would appreciate your guidance and experience.
1. At random time intervals, the power liftgate refuses to close down with the button. It does open correctly with the handle button and remote, however when I press the button for motorized closing, it stays put and has to be pushed down manually to be closed. It has happened second time in a row. Got it fixed 1st time from the dealership - however after 2-3 weeks it exhibits the same behavior. When pressing the button it gives a single beep and moves slightly sometimes - however doesn't go all the way. I have tried cleaning sensors on the back side pillars and in between the hinge areas, there is nothing obstructing the path to closure or lock mechanism however it just randomly stops working. I have not tried any reset of the liftgate mechanism by pulling out the fuse.
2. There is an audible clattering sound from the panoramic roof when it is closed, while driving on uneven road. Like the moving parts (glass - sliding cover - roof) have a bit of play and make vibrating sounds - feels like any rubber lining for sound damping is worn off. Does it happen normally or is it expected to have some play and any possible solution for it. The sound may not be noticeable to average passenger - but remains a concern for me.
3. The lane guidance system - two dotted lines within the digital dash panel - sometimes keep exhibiting random behavior. Even when the lane guidance is on, the lines remain gray - then sometimes they light up as green and start functioning if lane departure is sensed. However their function seems like uncertain and not reliable to keep behaving as expected always. Does it require any specific lighting conditions , specific type of road markers , and clean sensor position to correctly detect the lane adherence. Any ideas or similar experiences. Where is this sensor located - i believe in front center portion of dashboard under the wind screen.
4. The petrol average for (91 RON) in my typical city driving conditions (hot weather) is around 6.7 KM/l , is it ok or too low.
5. While pressing the pedal, from a slow 30-40 speed, there is sometimes a slightly rough vibrating feeling on the pedal while the turbo kicks (with a bit of lag) and the car shoots to higher gears and speed. It normalizes once it is intended range of fast speed. Is it normal and expected.
6. There are some slight vibrating click-clack sounds on uneven roads coming from the 2nd Row and beyond. Like maybe the seat belt metal latch is clacking against the plastic trim of the interior side body. I was more expecting a totally noise free experience and drive. Are these and similar slight vibration sounds normal and notice by other drivers as well.
Thanks for reading my detailed post and sharing your opinion and knowledge.
Regards.
Hello,
Regards.
This may be the problem with item #2: https://static.nhtsa.gov/odi/tsbs/2021/MC-10201618-0001.pdf
aggiegrad05
North Texas
Hello,
Regards.
On #3, the lane departure system only functions above 40mph...so if you're below that speed they will remain grey. The sensor is in the rearview mirror housing:
It is blocked or dirty, the guage cluster should give you an alert that the system is unavailable.
A
AlterEgo
KSA
Got it, will check it on my way back from work today, if the lights become alive only after 40MPH. Probably the lane divider markers may have to do something with it as well. For some roads lane markers (white/yellow) are painted on, some other have cat-eyes pegged in the roads as dividers. I could be wrong, will check anyways.
Gumby
Beaumont, Alberta
Have you recently changed out your windshield? If so, you might have needed to recalibrate the sensors up there. That might help explain the erratic sensor behaviour?
A
AlterEgo
KSA
Well no, touch wood - to my info and car service history from the dealership the wind screen is stock factory and not touched. I dread of a time when I have to get it replaced - which usually happens in case of grave damage :)
A
AlterEgo
KSA
In continuation of the thread, I did try a feature which apparently doesn't work for my vehicle. It is for remote button combination for auto start - turning on the A/C and lowering down all windows to vent out the hot accumulated inside, before the driver steps in.
I did try the button combo as guided in the manual, however it doesnt work. The auto ignition start works - however it also remains in a intermediate stage where the driver still have to press the start button upon ingress (which probably kills purpose of auto start - since the driver will press start button anyways without auto star).
Is it only available in higher trims and not in XLT.
Can anyone try and share their experience.
Thanks.
apex96
It’s a safety feature. All vehicles once remotely started will require you to push the start button to gain full functionality and drive away.
A
AlterEgo
KSA
Sure this is what I thought as well.
I was more keen to know about the below, which somehow wasnt working on my 2020 XLT. Is it something reserved for Limited / Platinum trims, or something which can be act/deactivated by specific firmware version. Can try to check with my dealership accordingly.
ROBERT BONNER
Denver, NC
Relative to item #3, I've driven in many countries; however, I've never driven in Saudi Arabia. The the lane departure system relies on painted lines on the road to locate the vehicle. In the absence of well painted exposed lines on one or both sides of the road the system turns the dotted lines gray on the side where the line is absent or obscured. The discussion above relative to keeping the windshield clean where the cameras are is pertinent as well; but, if there are no lines on the road, it won't work. Here in the U.S. different states and localities have various levels of road maintenance. When I travel to Northern Michigan, many roads are crumbling and have no lines; so, it doesn't work.
Relative to item #4, it depends on velocity. Here in the US where we have a lowest common denominator approach to speed limits; I'm ashamed to admit that I have never cruised for a long distance in my Expedition at more than 140 km/h. At that speed, I get 8.5 km/L. I would imagine that fuel economy would degrade significantly at higher speeds. What speeds are you getting 6.7 km/L?
Relative to item #5, I experience the same, it's irritating and I believe it is either poor PCM programming, or possibly engine ingestion of crankcase gases and liquids through the PVC system causing poor combustion.
Relative to item #6, what speeds are you experiencing the sound at? Keep in mind that despite being a "GCC" spec unit, the drivetrain has not been dynamically balanced. I expect there are dealerships or shops in KSA that specialize in high speed powertrain dynamic balancing, which would reduce high speed vibration that may be "driving" the noise(s) you are hearing.
BTW if you have a '20 XLT, you don't have leather seats, they are Naugahyde. It looks and feels very much like leather; but, it is synthetic.
A
AlterEgo
KSA
Thanks for the Naugahyde "revelation". It really added to my knowledge. XLT 2020 with package 202a is advertised as "XLT Leather" by the local dealerships - hence I came to know its not real leather - ::makes sad face:: plus false advertising to the unknowing customers.
For Item # 3 : I am kinda not sure myself and facing unpredictable behavior from lane guidance system. Probably the lane divider markers may have to do something with it as well as you mentioned. For my location some roads have lane markers (white/yellow) painted on, some others have cat-eyes pegged in the roads as lane dividers. When it works, i believe it works well in low lighting condition as well. However still am guessing what triggers it to work and why it goes grey sometimes. It is not the speed >= 40KM/h for me.
For Item # 4 : I have driven at long distances 400-800 KM inter city routes at around 140KM/H . I have an upcoming trip of around 450KM where I will better observe the fuel average. The 6.7 KM/L average is based on daily city commute with multiple strides of stop and go (signals / traffic / rush hour) where the speed mostly remains the range of 30-95 KM/H. As you mentioned, sorry for my limited understanding, please correct if needed, I assume fuel economy should improve at higher speeds and stretches of uninterrupted driving (instead of getting degraded).
For Item # 5 : Ok, so it is something which happens. Well it will be kinda hard to explain to the dealership servicemen in my next warranty checkup and service visit - as to what I want to be rectified or calibrated.
For Item # 6 : The sound was not actually felt under the floor or coming from drive train. It was more of rattling / clacking from inside the drive cabin. So was asking most usual possible suspected areas which I can scan. I assume any drive train calibration would already have been performed by authorized dealerships while/after importing GCC specs units.
Cheers.
KPhend
Indiana
As far as the lane keeping goes, the lines are grey if the system doesn't "see" the lines on the road. If there is only a center divider line then the right display stays gray and doesn't function until it sees a line and vice versa.
Dewey3
The remote windows up/down feature are separate from the auto start and as you have noticed, not on the XLT. I've played with FORScan looking for that, but have not been successful... it might require a physical module.
wakeboarder
Fort Lauderdale, FL
The 2019 XLT’s allowed global windows through Forscan for the front two windows. If you have the one touch up and down windows, then your hardware should be correct. Have you checked the Forscan section of this forum? I believe the 2020’s are different than the 2019’s. You would likely have to enable things on the BCM, drivers door module, and passenger door module.
A
AlterEgo
KSA
Thanks for introducing ForScan. I have never used it. I mostly just used Torque for getting the info with my previous car - not making changes to any factory settings.
Can you inform if ForScan needs a particular model/build of OBD adapter or will it work with any run of the mill bluetooth OBDs. I have the following one
Will it allow me to make any changes. As I read in the ForScan forum quickly it always cautious to backup the settings before making changes.
Secondly for any config modification via ForScan - will it void the warranty status or the dealership would have a way of knowing about it upon the next visit.
Any post you can recommend for beginner's intro to ForScan.
Thanks.
