Glitch in instrument cluster in 2022 Timberline?
tacoman
Boston
Just got my new Timberline with the big LCD screen and I love it! One thing I have noticed, however, is on the instrument cluster (not the LCD screen), the 4 gauges across the top will sometimes shift inwards causing them to overlap with other things on the screen. See the attached picture where it is overlapping with the GPS directions. It seems to fluctuate back and forth, and sometimes even changes as I drive the car. Has anyone else come across this issue? The "normal" position would be two gauges mostly above the tach, and the other two gauges mostly above the speed with a gap in between for the GPS directions.
Rob6805
You found a bug. You can contact the dealer and see if there is a software update available yet that will fix it.
LazSlate
Arizona
None here. Maybe its the tilt indicator. Try changing the main display center to something else and see if it still happens.
Lou Hamilton
I have not seen that yet. I just crossed 3200 miles on mine and use Apple CarPlay navigation.
My bigger issue is that the Transmission Temp indicator will not stay on. It keeps resetting to the Power Boost after each restart of the Expedition.
alademann
Cave Creek, AZ
How do you get the boost to be replaced by transmission temp (even temporarily - I haven't found that function yet)?
JustMatt76
Clearwater, FL
I've got 1600 miles on my Timberline and haven't run into any of those issues. The only thing I've had a problem with is Apple Car Play not connecting to my phone after it connected to my wife phone and her phone is still in range. Not a huge issue but annoying......only thing I can think is to see if a over-the-air update will fix it or take it to a dealership to see if they can flash the computer???
MikeS3000
Johnstown, OH
Did you ever find a solution to get the custom gauges to stick after restarting the vehicle? Mine does the same thing and it's annoying on my '23. My '18 that I sold did not have this problem.
LazSlate
Arizona
I had that issue when using navigation and certain gauges like the tilt. No big deal.
