Why is the cam phaser rattle bad?
George Banks
Washington, DC
I’ve searched the internet and this forum, but I can’t seem to find a clear answer anywhere. Even Ford offers a different response than what I’ve read online. Why is the cam phaser rattle such a big deal? My 2019 is now making the common noise at cold startup - 36k miles. I called my dealership and they said they could replace the cam phasers if I wanted, but that’s it’s not necessary. He said, “it’s just a noise at startup that has zero impact on the engine or SUV”. So what’s the real story? Is it bad? Is it a sign that they will eventually fail and that’s the issue?
If this was such a problematic issue, I guess I would expect to see more horror stories of catastrophic engine failure. If the service tech is right and this is “just a noise”, I feel like it’s a bigger gamble to have them take apart your whole engine and put it back together with the hope they don’t mess up something else. I’ve read countless stories of people having other issues after the cam phaser repair. I don’t know what to think of it all. What’s your thoughts?
Bmac1955
Southern Cali
I had them done at 35k. Replaced phasers along with a cam. I had no concerns with the repair procedure being inadequate. Although I purchased a Ford extended warranty good till 125k. I enjoy both aspects. Comfort and peice of mind. If it fails I'm covered for $100. I just hope I am not a 1000 miles from home stranded. That would be bad thing.
duneslider
Utah
I have heard from a couple ford tech's that there is nothing wrong with the rattle, it won't cause any problems long term. It's just a little annoying at start up.
A few people have mentioned getting some CEL's but I think when that happens there is something else going on in addition to the rattle. The rattle itself is only at start up and once there is oil pressure there is nothing else going on, so if a CEL is showing up during driving it is something else. I don't think there is anyway the rattle could cause an error to show up in the computer.
kjtully
Monument, Colorado
Couple of things: if 'it's just noise' then why is there a fix for it; lack of oil pressure means no oil. In all the years I've owned cars and done my own oil changes there is always the issue of lack of oil on that first start, and the attendant wear on internal parts, until the oil pump fills the new oil filter. No or insufficient oil means metal-on-metal contact and additional wear. Seems the same would be true with the cam phasers - no or insufficient oil means metal-on-metal wear that would result in part degradation that could eventually lead to part failure.
If 'it's just noise' Ford has sure put a lot of money and time in to replace the cam phasers. Doesn't the rattle occur because a pin has broken due to the additional wear of no oil at engine start?
Jettix2
Frankfort, MI
I find it really, really hard to believe that Ford is doing all this work on hundreds of thousands of 3.5 motors *for free* just because it’s noisy for 5 seconds when we first start it. There *has* to be long term wear happening without that lubrication. Ours suddenly has started making the cold start noise, threw a CEL, and is having drivability issues. We’ll see if ours is “fixed” when they do the repair in 2 weeks.
Soliyou
OK
This rattle is basically vibrating the timing chains, camshafts, and valve-train. You definitely don’t want it to be going for a long time.
BMW2FORD
CT
When the phaser is rattling, it’s slamming it’s internal parts around. If it fails, the engine will immediately fail as well. I’ve seen the updated phasers and just had them done and now they are making a new louder noise more like a lifter on cold and hot start. That happened a day after they were replaced and I’m besides myself. To me, the updates to the phaser is Ford just trying to keep it from coming apart and the most biggest failure from happening. The SW is to try to increase the oil supply to them. It’s clear Ford is kicking the can down the road on us customers with this problem and many others. I sent a video to my dealer of the new noise and and have an appointment and will post back what they find but man this is annoying and my third set of phasers. Many people in this forum mention the 2021’s and later have a different cylinder head with more oil flow. Why doesn’t Ford update our engines to what the 2021’s have? In the long run, that would be less Warranty expense for them and happier loyal customers in the end than 3x or 4x sets if phasers. In my opinion, Sales sells the first car but good service and repairs will sell the next and many more.
Jettix2
Frankfort, MI
I'm real interested to read more about this newer design head.......seems like that might be more of a root issue behind the cam phasers failing.
BMW2FORD
CT
Hi all, see the below thread page 2 for the updated head info. I’m not 100% in this but interesting they have made this change and the later engines don’t seem to have this problem.
proftomda
georgia
If you want to avoid the repair and help save your engine just utilitize “flood mode” by holding the gas pedal to the floor and cranking the engine 5 seconds or so to build up oil pressure in the phaser. After cranking for 5 seconds or so just take your foot off the gas and it will start normally. The engine will not start with the gas pedal to the floor.
G
George Banks
Washington, DC
Thanks for the feedback, all! I’m probably just going to take it to the dealer and start the process of replacing the cam phasers. Sounds like the noise is just a sign of trouble to come, so I should just get it fixed while they are offering to actually do the repair.
curtis-bob
Kansas
Good idea.. Only draw back is the more work on the starter and batteries... But both are far less to replace then engine damage..
LazSlate
Arizona
The CAM Phaser issue is not lack of oil pressure on start up. Its the locking pin not seating correctly at shut down to save the base timing. This is the entire concept of the CAM Phasers since there is no oil pressure at start up. The timing runs on the VCT Solenoid which is oil powered so when engine is off there needs to be a way to lock the timing.
One trick that seems to work for some people with CAM Phaser rattling is before shutting down let it idle of a minute or more this somehow helps the Phaser Pin to lock better. Not a fix but a stop gap maybe until Ford addresses this.
blue_roster_cult
Missouri
NukeLife
Charlotte
Agreed. Under normal operation engine oil is ported to the phaser via the solenoid. The amount of oil directed to the phaser is variable, which results in advancing/ retarding the mechanical timing of the camshafts.
Agreed. The engine has no oil pressure on cold starts, and relies on the pin to “lock” the two concentric halves of the phaser together at the base timing position. It holds this position until oil pressure is sufficient to start doing its normal job again.
Agreed. Those engines experiencing the loud knock for 2 seconds on a cold start are hearing it, because the pin is not locking the two halves of the phaser together. And that is the sound of the two halves slapping violently back and forth as the outer half is being suddenly driven by the timing chain (around the crankshaft). And the inner half (connected to the camshafts) vainly struggles to keep up.
For those thinking this “isn’t really a problem”, eh.. ok.
After two or three seconds, enough oil pressure exists for the solenoids and phasers to do their job.
Where we differ in opinion is the root cause.
The failure mode, as I understand it, is that on some engines, the VCT solenoids are experiencing inadequate oil pressure early in the start. This has been validated by NDE at Ford, and measured by additional instrumentation test runs on engines pulled from vehicles that had multiple VCT failures.
This sub-optimal oil pressure is believed to be a result of inadequate sealing at the megacap end of the shaft. Since oil pressure builds too slowly at the megacap following the engine start, no oil pressure makes it into the phaser to disengage the pin and resume normal operations.
So as a result the pin stays locked in FOR TOO LONG—much longer than it is supposed to. This side shearing action on the pin is what is responsible for that worn, irregular looking “ramp”. Because the pin isn’t cleanly disengaging on startup. What you are seeing in that photo is a symptom of the problem—not the root problem, which is inadequate oil pressure at the megacap.
But, you don’t see or hear this. It just happens. Over. And over. And over… until (30,000 miles later) the repeated stresses on that puny little pin result in fatigue failure, and ‘snap!’
The pin breaks.
And then the next time you go perform a cold start….. KNOCK KNOCK KNOCK.
who’s there?
Ford Makulako guy has a video showing one these broken pins. That part is not theory. Mine had one broken pin, and one degraded.
Is it simply due to the phaser pins not engaging on some of these engines? Sure, that’s possible.
Could it be a combination of those two popular theories? I’d say likely.
Will we ever know the whole story? Hell no, then Ford would have to replace a lot of long blocks.
