Headlights suck, couple questions:
makenzie71
Tx
Our headlights are terrible...almost no difference between high beam and low beam, poor spread, just bad. So I'm looking at installing some bi-led morimoto modules.
First question: Before I go through the effort and expense, are there any drop in options available that will improve the light? Will the Navigator xenon headlights swap over (and are they better)?
Second: Has anyone else torn the headlights apart and installed morimoto/similar LED's or xenon modules? Can you bake the headlights apart to disassemble them or are they glued?
rwmorrisonjr
Memphis, TN
I can't answer about the Navigator xenon lights but I doubt it due to the different housing styles.
I've done a Morimoto xenon swap and you can bake the headlamps apart. You'll need to get their butyl sealant tape to reseal them afterwards and you'll need to bore out the light hole to fit the projector properly. I've found they also tend to condensate more since the butyl doesn't seem to seal as well as the factory. If you want to PM me, I can tell you more since I have an entire assembly (headlamps, igniters, and bulbs) sitting in my garage unused.
bloodhound
Merica
What year are you talking about? I and others here have installed these with great results. Huge difference. Mine is a 2014 so I can't speak to 2015-up which are a different design headlight.
rwmorrisonjr
Memphis, TN
M
makenzie71
Tx
It's a 2012. I've tried LED bulbs in the past and found the "upgrade" to mostly be placebo...lots of scatter and the "improvement" was mostly just the different color temp playing with our perception. I would much rather get better modules in the fixtures.
bloodhound
Merica
I understand, I have purchased other LEDs that were terrible. I will say that with these the LED modules are actually in the right place so the light placement and cutoff is great, and no blinding oncoming drivers. I don't have any before/after pics but for the price it was a huge improvement.
dcsang
I agree with this. Not all LEDs are the same. The level of brightness, beam pattern, and proper headlight alignment can make a big difference. Many of the LED replacements tend to scatter light, and do not produce a distinct cutoff.
M
makenzie71
Tx
I might try a set but my preference is proper bi-xenon or bi-led modules.
muskytom
Illinois
I'm a little late to the game on the thread and checked out the lights you linked (and rwmorrisonjr too). Any problem with flicker? I posted the question on amazon referencing my 2013 LTD and said not problem, but would also provide a canbus if that was the case. Curious as to your experiences.
rwmorrisonjr
Memphis, TN
No problems with flicker and I'm running with DRLs enabled. No CANBUS errors either.
