Front bakes grabbing, grinding, and chirping after suspension refresh
rwmorrisonjr
rwmorrisonjr
Memphis, TN
UPDATE: Truck is aligned, but the Firestone tech said he couldn't adjust the camber since I didn't install a camber adjustment kit when I swapped out the LCAs! What a bunch of garbage since they've been able to set the alignment with the factory hardware since I bought he truck!
The front brakes are still dragging evenly but not pulling to either side. Still trying to troubleshoot this since I find it very hard to believe that both calipers and flex lines have failed in the exact same way. Now I'm leaning toward the master cylinder based on the even dragging of the calipers.
Retiredusps
N.J.
By chance did you put 1 pad in backwards steel to rotar pad to caliper, son did it by mistake. First brake job,learned a lesson. His pickup did same thing Grinding, squeak and pulling
rwmorrisonjr
rwmorrisonjr
Memphis, TN
No, I pulled them all again yesterday to check. What's funny is that they're Motorcraft pads but don't have the tabs/ears on one pad to mark the inside pad. Will check them again in the morning and maybe swap them around to rule that out.
I also ordered new flex lines as a preemptive next step since they're hard to find right now.
rwmorrisonjr
rwmorrisonjr
Memphis, TN
Interesting find: I looked up the part number for the pads the dealer gave me (AU2Z-2V001-E) on FordPartsGiant.com and they can't confirm they fit my truck; research shows they fit F150s.. Instead, they list AU2Z-2V001-F or 8L3Z-2V001-C/ 8L3Z-2V001-B as the correct fit for my truck. The pads I have do not have the tabs/ears on them to differentiate inside from outside pads. Going out on a limb and thinking this might be the actual cause of my brake dragging issues. Thoughts?
David Schaefer
North Texas
I wish I knew. I guess you could look them up at Autozone.com or Rock Auto where it shows pictures of the various choices that fit your ride. Compare what you find to what you installed.
Retiredusps
N.J.
I would also check the steel brake lineswhere they go thru the plastic keepers up here rust between them and the line have crimped them but not enough to leak. (salt should only stay on the table )
had to do rad support from salt eat away at frame mount.Son purchased a pickup turned into rust bucket, previous owner use to take it on the beach and into the ocean.
rwmorrisonjr
rwmorrisonjr
Memphis, TN
Luckily I don’t have the rust issues (originally a VA truck, now in TN) so the steel lines are clean.
Really want to track this down since this most likely started happening when I changed the brakes in July but only noticed it when I did the suspension refresh.
rwmorrisonjr
rwmorrisonjr
Memphis, TN
Just checked oemfordparts.com and the kit I got from the dealer (AU2Z-2V001-D) is listed for F-250s/350s and E250s/350s! Definitely going to get the right pads and see if that fixes the issue!
mjp2
Howell, NJ
He's not wrong. They simply never adjusted (or had to adjust) camber on your truck prior to this as it was set at the factory. His statement is accurate.
rwmorrisonjr
rwmorrisonjr
Memphis, TN
Ok, thanks for the clarification. Guess I'll break down and get the camber kit at some point after I get the brake issues sorted out. I'm good on camber on the right and "on the border" on the left. Truck is still tracking straight.
rwmorrisonjr
rwmorrisonjr
Memphis, TN
Just checked oemfordparts.com and the kit I got from the dealer (AU2Z-2V001-E) is listed for F-250s/350s and E250s/350s! Definitely going to get the right pads and see if that fixes the issue!
Just went to the dealer and checked everything on their computer. AU2Z-2V001-E was superseded by AU2Z-2V001-F and shows as a fit for the Expedition and F150, so no luck there. Will try swapping the pads around in the calipers and see if that makes a difference since the pads aren't marked or tagged for specific inner/outer placement. If no luck, I'm stumped unless the master cylinder has failed somehow since I find it hard to believe that both calipers and flex lines would fail the exact same way at the same time.
rwmorrisonjr
rwmorrisonjr
Memphis, TN
UPDATE: pulled the driver’s side caliper, swapped the pads, and cracked both the master cylinder line and bleeder screw. Tested it all and no more dragging! Not sure what I fixed, but I’ll take the win on this! Truck now rolls freely out of my garage (very slight incline, good low speed test) and doesn’t feel restricted while driving now. Will keep an eye on it but (fingers crossed) all seems good now.
Thanks all for your input!
mjp2
Howell, NJ
Honestly the whole thing made no sense to me until I went through the process of replacing the arms and installed the kit myself. Seems crazy to me that the trucks are not adjustable with the factory-installed hardware. The alignment shops love it though because they only have to center the steering wheel and adjust tow-in.
rwmorrisonjr
rwmorrisonjr
Memphis, TN
I agree, but I guess there aren't many techs out there that are comfortable with the prybar method of setting camber! :D I'll order the kit and install it next month then have it realigned permanently. There's also a shop a friend uses that pretty old school and might be able to do it without the kit.
