Catch can
chaffdb
Hattiesburg, MS
This is a pretty good thread if you haven't seen it. Helped me make my decision, and I posted a bunch of photos from my UPR dual side "plug n play" install on pages 7-8: For Those Who Don't Think a Catch Can is Needed on Gen 4 s...
I will say that in about 1500 miles of driving after install, my driver's side/"clean side" can had nothing in it. I double checked all connections and talked to the UPR about it to make sure everything is ok. They said that is common and that it is will over the long term accumulate some from time to time, but the clean side will not need to be emptied every oil change or even every few.
So, yeah, while I like the idea of it, the single side cans as being recommended here offer a lot of bang the buck, so to speak. I believe UPR will sell a single sided can with nice quality lines and connectors and such, but it will be a price premium over the J&L which, by all accounts, works well.
TheDoug
Mansfield, TX
I also went with the UPR model because of the dual side design. I go ahead and drain mine every oil change just because... might as well while I am under there. The UPR has a drain valve at bottom that you have hook up a hose to to easily drain. (close valve and remove hose when done draining)
Moderator
Is the drain/hose an add in, or comes with the default setup.
5280tunage
colorado
That seems even more messy in an engine compartment... I actually think the threaded can that just unscrews is super easy, I add the oil in it to the oil I measure every time I do an oil change. I'm good with my current setup but always nice to see others. Heck, for those of us with these, it's more than probably 90% of owners will do.
chaffdb
Hattiesburg, MS
I believe it comes standard with a plug, and you can either unscrew the can or remove the plug. It might come with a valve that doesn't have a hose. I'm not certain. They do have a magnetic plug option or the drain line kit. Mine, ordered with the drain line kit, came with a valve installed, and then it came with another valve with a nipple, some angles, and the drain hose for lots of routing options. On the kit I bought, it is advertised as:
UPR Catch Can Drain Line Kit:
The drain line kit includes a drain valve, hose and fittings needed to install the drain valve. It allows the user to relocate the drain somewhere easier to access like the wheel well opening or bumper area.
**You would select either the Stainless Steel Magnetic Drain Plug or The Catch Drain Line Kit, not both.
It's actually very clean. The hose on mine is meant to stay in place. I routed the drain line down to the frame just behind the front bumper, nearly straight below the where the can is located, and it is zip tied in place. Just slide the drain pan over and open the valve. Or, what I plan to do since I want to catch what comes out of it like you do, is set a jar under it. Mine has dual cans and the clean side has to be unscrewed, but as I mentioned above, after 1500 mines there was nothing in it, so I'll probably only check it once a year or less.
TheDoug
Mansfield, TX
The catch can installs behind the driver side headlamp on the frame so you can hook the hose up there to easily drain it. It can be reached without removing anything.
The hose and threaded fitting is sold separately. They do sell it I believe but I reached out after I purchased and they told me what threaded fitting to get and I ordered on amazon.
MxRacer965
Hudsonville, MI
What’s the P/N for the J&L can nowadays? Used to be JLT was it not? Directs to SBFilters, and they don’t list a can setup for the Ecoboost that I’ve noticed. Amazon does but when looking up on their site it points to the 5.0 with supercharger.
Moderator
18-21
22+
Andy B
Redding, CT
Don't waste your money. The newer eco boost engines have port injection rather than direct injection. That means the valves are constantly sprayed with gasoline rather than just having air passing over them. The direct inject air usually is a mix with re-ingested pcv gunk that a catch can would collect. The port injection sprays gas over the valve along with the re-ingested air mix, and the gasoline cleans the valve keeping it carbon deposit free. Just make sure you use good gas with detergents like mobile, and throw some fuel cleaner in there every once in a while and you'll be good. I almost did the same thing in getting a catch can, and I'm glad I learned about this from another fellow.
The newer ecoboost engines have BOTH port and direct injection.
Andy B
Redding, CT
Having just ordered a new 2023 Expy SPP this thread got me reading up on catch cans. This will be my first forced induction engine.
On some online resources (F150 forum for example) they seem to think the addition of port injection on the newer EcoBoost motors makes a catch can less important.
It's still "better" but the difference in fouling could be lesser.
Anyone have any good links or knowledge to share on this thought?
TheDoug
Mansfield, TX
It will help regardless of the addition of port injection. I still get plenty of junk out of my catch can each oil change.
Now is it 100 percent necessary, no...
Moderator
18-21
22+
@Andy Bajorinas Here are the kits for the 4th Gens from J&L
Moderator
It was discussed in this thread above, and in the other also.
Expoxone
Palm Beach Gardens, FL
Nope, you would be incorrect.
Whoever told you that was 100% incorrect.
The Gen2 3.5(Gen 4 - 2018+ Expeditions) Twin Turbo Ecoboost motor has BOTH port and direct. Under MOST situations the direct injectors are used, because of the more accurate fuel metering that can be delivered. Port is used for Cold startups, and under low load. The DI picks ups once up to operating temp and high loads, and under real high load and demands for fuel, both injectors are used.
Edit: Clarity on above. So basically when you are a greatest risk for deposits(High Temp and under load) the motor is in DI mode, and you are getting ZERO washing of the valves from the fuel.
It does not remove the need for a catch can. Heck some of the most powerful Port injected motors on sale today come with them(Some Hellcats), and are highly recommended in many port injected applications also. The port injectors even being used sometimes does help to decrease the buildup of deposits, but does not remove the risk. A catch can prevents the majority of what causes the deposits from ever getting to where it can cause them. PERIOD. A catch can is NOT about the short term, but the long term.
Cool! Good to know.
MxRacer965
Hudsonville, MI
Installed J&L catch can before running out the door on vacation. I routed the line into the PCV as they show. The intake I ran under the wiring harness for the cam phasers, etc instead of on top. Seemed less likely to rub and cause a problem long-term.
