Catch can
ultra flash
new york
I have a 22 Exp Stealth Performance Package and Raptor motor.
Want to install a catch can any thoughts on what and where to order?
TY
Defyant
Rising Sun Md
Im just going to order one from Ford Performance Parts for the Timberline with same engine.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Expoxone
Palm Beach Gardens, FL
Don't waste your money. The newer eco boost engines have port injection rather than direct injection. That means the valves are constantly sprayed with gasoline rather than just having air passing over them. The direct inject air usually is a mix with re-ingested pcv gunk that a catch can would collect. The port injection sprays gas over the valve along with the re-ingested air mix, and the gasoline cleans the valve keeping it carbon deposit free. Just make sure you use good gas with detergents like mobile, and throw some fuel cleaner in there every once in a while and you'll be good. I almost did the same thing in getting a catch can, and I'm glad I learned about this from another fellow.
