Running Boards
rd618
new york
I don’t mind this feature. I have small kids also, if more than 30 lbs is on the step it won’t retract. Even my smallest is more than that.
Beachums
Indiana
I am willing to bet it isn't a "feature" at all. I am thinking it was done out of simplicity.
My two prior vehicles that had them were exclusive to the side opening.
I am wondering if this facilitated a consolidation of modules.
Rob6805
And yes, obviously the only running board that should actuate is the one on the side with an open door.
Mine on my 2018 work exactly as they should.
And they stay up in the stowed position if I change the setting, also.
Why Ford decided to screw with this is beyond me. Almost seems like maybe it got unintentionally changed by a wiring harness error, or programming error in the BCM.
Yes, for sure it was a chip shortage thing. Independent opening running boards no doubt require additional sensors/modules.
rd618
new york
so is my grandaughter but it closed on her foot
That’s not supposed to happen, I checked mine as soon as I got it because I was worried my son would climb on it when it would retract, he does, and it won’t go up. The side just stays down. I tested it with a 30 lb dumbbell first. Didn’t even try to lift it, just stayed down, other side went up like normal.
Might want to get a dealer to test it for you.
NukeLife
Charlotte
Ah. Hadn’t considered that the chip shortage could have something to do with it. Definitely a possibility. Only one final output circuit. Simpler sensing circuit.
how hilariously ironic it would be, if the total cost of the resultant recalls ended up costing more than what Ford “saved” by trying to use fewer chips in the circuit.
rd618
new york
I was talking to a tech for another tire balance issue, I asked about the running boards, he said they are likely going to come out with a sync OTA update to fix the double down and timer extension issues. he said they are mechanically the same as prior years, and the system that controls them is the same as the door ajar warnings, so they can operate independently.
Rob6805
Oh, that would be great if they can correct it with software. Makes sense that it uses the door switches.
Infra246
Canada
I noticed something strange when getting out and rubbing my leg against the running board it seems to have a trim that pushes in. All past trucks I always thought the running board was one solid piece. Not sure if something has changed but it looks like the painted part is a separate piece and whatever adhesive is used to seal it together has failed. I suspect that left unchecked this will be a problem for water intrusion and corrossion down the road, especially in the winter. The passenger side feels pretty solid but the drivers side is separating all the way down the length of the running board. See video..
Running Board Video
1badhabit
Missouri
Just to add to this, the F150 power boards behave this same way (both deploy with any door open). I'm not sure if they used to be independent but they've been this way a while.
Mommy3610
Memphis, TN
The double deploy is definitely a nuisance, but my main concern is the fact the timer option doesn’t even work. If they don’t fix this issue soon, motor burnout is going to be costly for Ford. I should be able to put my kid in his car seat on one side, and then get to the drivers side without them closing up so quickly. It’s not only annoying, but a safety issue.
Rob6805
Well that's just dumb. RAM pickup's running boards operate independent.
Alwaysthinkin
Georgia
Wish they would fold under after vehicle has started moving, like the door locks that lock automatically. That would leave them extended in parking lots and eliminate need to hurry in the loading process.
m3olsen
CNY
Sharing current running board performance on my 22 Limited 304A SPP that was built end of August 22 as it's possible some things may have updated. When I unlock the doors, both running boards extend. If I don't touch a door, I timed 22-23 seconds and then they will close themselves. If I open a door, they will remain open for as long as any door is open. Once all doors are closed, they remain down for just over 2 seconds, then both close.
Personal commentary: FWIW, my general practice is to unlock and crack driver's door open - keeping boards deployed. Load/ unload anything and everything that is transferring, and then close drivers door when I know I'm done. In my mind, that both minimizes the number of times the boards bounce up and down, and keeps everyone safe from an accidental pinch.
USKflt
Anyone heard of any plans for Ford to issue an update to fix the running board issues? Saw someone alluding to this but haven’t seen any updates come through and my dealer is zero help. Don’t want to leave it there for a week for them to tell me that’s how it’s supposed to operate.
bigwilly
My '17 F150's factory running boards work independently on each side, so must be a more recent change.
