Leaking Shock
Schulminator
Oviedo, FL
Just noticed fluid on our garage floor this morning. Peaked under and there is fluid on the bottom spring perch front passenger side, and lower control arm. Is this a known issue?
2022 Limited Stealth package with 1600 miles...
dlcorbett
Air Force
tx
Does it have ccd or no? The base springs are notorious for leaking, but you maybe the first with a 22 that has a leaky spring.
I you do a search on this forum, you will several long threads about leaking shocks on the Expedition.
I bought my 2015 Expedition Limited 4x4 new, and the RF shock leaked by 3,000 miles (strictly passenger use). It was on national backorder and took the dealer several months to get and install.
Schulminator
Schulminator
Oviedo, FL
Non CCD
I did a quick search, all threads I could find were for older Expeditions.
Are there any aftermarket options for this model year?
sjwhiteley
Kentucky
Non CCD
Yes there are. Bilstein 5100 are a good aftermarket shock. This is, I believe what most people go with. I can’t believe the newer ones have this issue. With how few miles you have, I’d take it to the dealer, though.
Schulminator
Schulminator
Oviedo, FL
Thanks, yes going to dealer today.
Lee Dame
Webster, NY
I have a 2018 Limited MAX 4WD with the Towing package (no CCD) and 1 had 2 leaking shocks before 8k miles. My dealer replaced all 4 since they found a 3rd one that had started to leak but had not yet gotten to the point where it was leaking on the floor in the garage. So far, the replacements have held up (at 26k now).
BSarchet
Little Flock, AR
I have 12,700 on my 2022 and just found clear fluid on the garage floor. I looked underneath and it appeared to originate below the spring and traveled back along the undercarriage on the passenger side. Also have the HD tow package. I assuming it’s a leaking strut but I dropped it off at the dealer today. Hopefully the back order is over. Does anyone know what problems this causes if I do have to drive it like this for a while?
Soliyou
OK
If the shock is completely toast (rattling and clunking) you have a high risk of damaging the tire which could be really bad at highway speeds.
ManUpOrShutUp
My '11 EL had 3 Ford rear shocks blow out by 110k or so. I went with Bilsteins at ~110k and am still running them at 208k. My mom's 2019 Explorer blew both rear shocks before it hit 10k. Ford struts/shocks just suck.
kylenobbe
st. louis
My 2019 max with 60k miles has a rear passenger shock absorber leaking. PremiumCare ESP won’t cover it since it’s considered a maintenance item…
