This forum. Post number 22 has pictures.Do you know where I can find a diagram/location for the sensor?
This, it's easier to activate it accidentally when you don't want to than when your arms are full of stuff and you need it to work. Make sure you are kicking in the right place.How do you know it isn't working? Are you kicking under the bumper correctly? It's a crappy system. I probably look like an idiot trying to get it to open. Probably less than 50% rate as to whether it works or not.
I have '18 XLT. Worked for a few months. Then lift gate started opening by itself. Caught me on the forehead. Dealer tried everything without success. Disabled kick to lift.2018 Max Platinum with the hands-free option not working. All other methods work fine and the option is enabled on the dash options. Bought it used so no idea if it ever worked. Where and what do I need to check?
Anyone have access to the service manual steps in diagnosing the components?
I had an '18 and now a '21. Accidental activations aside, I could barely get the '18 to work when I wanted it to. I feel like I had to start more towards the driver side than center and kick at some weird angle for the times I did get it to work. The '21 works pretty flawlessly with a simple short kick starting at the center.Tried from about all angles and methods. Verified everything plugged in and activated in Forscan. I'm out of ideas... anyone?
