No need to hold off for better weather to test the 2H possibility,
@dnprall and
@LokiWolf . Driving home from work last night (again, less than 10 mile trip), I got the error messages again - this time I was in 2H the entire trip. "Check electronic limited slip differential", alternating with "Service vehicle soon" and the wrench icon in lower right corner of dash. Everything was cleared when I started up this morning. Roughly 90 miles from when it happened the first time. I got pics of dash display again.
Which of these messages are you getting?
Check Electronic Limited Slip Differential
Displays when the system requires service.Have your vehicle checked as soon as possible.
Electronic Limited Slip Differential Off See Owner's Manual
Electronic Limited Slip Differential Restored to Normal
Displays when the electronic limited slip differential system resumes normal function.
Electronic Limited Slip Differential Temporarily Disabled
Displays if the electronic limited slip differential system temporarily turns off due to overheating or an undersized spare tire. If you have an undersized spare tire installed, replace the spare tire with a full-sized tire as soon as possible. If not, stop the vehicle in a safe location and allow the system to cool.
Electronic Limited Slip Differential Reduced Torque
Displays if the electronic limited slip differential has limited functionality.This could be due to an undersized spare tire or caused by the system overheating.If you have an undersized spare tire installed, replace the spare tire with a full-sized tire as soon as possible.If you do not have an undersized spare tire installed, the vehicle has reduced functionality.Have your vehicle checked as soon as possible.
Electronic Limited Slip Differential Locking Feature Not Available
Displays when you select a drive mode that does not allow the electronic limited slip differential to turn on. This may also display when the electronic limited slip differential has a fault and the vehicle requests the locking feature
