2015 Limited EL Fan on high problem
michealmyers
MS
Strange prob. Now I know the fan is supposed to run on high on hot days etc, but recently in the last week it's done it in very cold weather.
Not sure whats triggering it but even when running the heat the fan will kick on, and of course it does it with A/C on.
I read where it could be the A/C pressure switch that needs to be swapped?
adamsdaddy
Orange County
Check your coolant tank-could be low. My 2016 has a leak at the very common turbo coolant line on the driver's side. When it gets low the loud secondary fan runs all the time.
M
michealmyers
MS
Yeah thats the first thing i did. It was at the 2nd line on the tank and I filled it up a little past the top line.
M
michealmyers
MS
Noticed that if the AC or heat is not turned on, it's fine. Only seems to kick on immediately if either is pressed, wasn't like this in the past. Wondering if it needs the A/C charged or if the a/c pressure sensor needs to be replaced.
adamsdaddy
Orange County
I watched "The Internets" Youtube video and came away confused. At 15 seconds he says the cooling fans have been running on high however in the comments KCVision asks if replacing the pressure switch solved the problem with fans running on high...to which he replies...he never had the fans running too much???
On Tasca, the Ford part is $65.54. Looks simple to install however it is unclear whether it will solve your problem.
Timo2824
Wichita
Is it a pressure switch or transducer? If it's just a normal open switch you can see if it's closed, then verify that the ac system pressure isn't actually high enough to close it. Have you had your ac system worked on? Non-condensables will cause crazy high pressure in just a few seconds of compressor runtime.
M
michealmyers
MS
it's this https://www.amazon.com/Motorcraft-Y...t=&hvlocphy=9013947&hvtargid=pla-780663221960
I had some freon put in last year but no probs until recently when the fan decides to kick on automatically when started.
M
michealmyers
MS
So with the ac running it’s not cool. I can hear the compressor kicking on but it’s not cool. Obviously a slow leak somewhere. I’m guessing that would cause the fan to run high ?
GlennSullivan
NY & FL
These cars all have blend doors that both control the source and destination of HVAC but also mix cold and warm air. If it is hot out (80-90) and the AC is on and air is not cold, look for an AC system problem, however if is 60-70 out and you have the AC on, the blend door system is supposed to mix cold and warm air to temper what is coming at you. At least my understanding and how they function in my Gen 3s
M
michealmyers
MS
Hope this helps somebody else. AC pressure was high causing the fan to kick on immediately when it's turned on. Last year I noticed the AC wasn't really cool so I had it charged. When I took it in to another shop this year they said the pressure was high so they drained it and replaced low side valve which had a small leak. Filled to correct levels and everything is working fine, fan is back operating as it should.
Timo2824
Wichita
Who did you have overcharge it, was it a mechanic or did a parts guy dump in a can of 134a?
