Looking at this used Expedition.....
arock
Looking at a 2019 Expedition Limited with 50k miles. CarFax is showing regular oil changes and services but also some weird stuff with the transmission (replaced/serviced/removed & reinstalled/fluid flush) at 47k. Not sure if that would be a good thing or red flag or just someone entered the service info in wrong so it reflecting weird on CarFax. Was supposed to go look at it on Sat but they notified me on Friday that it had to "be taken to the Ford dealer for a software update and that it would take ~2 weeks" (vehicle is at an Acura dealership). Are dealers that backed up currently that a software update would take 2 weeks or should I be concerned about them taking to the dealer for something bigger? The car fax shows the notification about the cam phaser program but do not see that it had been performed already so it could possibly be for that but not sure how long that job usually takes.
Just asking for opinions on whether I am over thinking it or if I should probably pass on this one and continue waiting for something else? (I'm very over car shopping at this point....) Dealership is a decent drive away so I don't want to drag the wife all the way up there for nothing.
Hellwig
If it is a CPO, or you are willing to purchase an extended powertrain warranty, it should be fine.
BMW2FORD
CT
I have a 2018 and the C D F clutch drum bushing failed. When it was towed to the dealer, I met up with the Service Manager and expressed that not only did the car just leave us stranded but it also sometime nuetrals out as well as shutters. They did all they could and replaced the C D F clutches and drum, the valve body, torque converter, pump and flushed the trans and cooler. In Car Fax it comes up the same way. Trans is excellent now and I’m still under factory Certified Powertrain Warranty till 100k and currently at 75k. I’d love to sell mine at this point but have everything updated (turbos, phasers, all fluids and filters changed, new brakes and tires) and it’s running very well - it’s now just too big for us and my kids are getting their own cars.
Jettix2
Frankfort, MI
I would walk. There’s plenty of used expeditions out there. Find one that’s Certified / CPO at a Ford dealer and put extended warranty on it.
Jettix2
Frankfort, MI
PS, not sure what $$ you’re looking at but I just bought an immaculate 2019 Platinum Max for $55k and change, Blue CPO with only 28k miles on it in Michigan.
BMW2FORD
CT
I totally agree. We paid a little more for a Certified car but well worth it.
Maxine the Max
South Dakota
I just had my software and maps updated on my 19 a couple weeks ago. It took 2 hours.
Calidad
Call your local Ford dealer service department tell them your checking for recall status give them the vin#. Ask while they are in there about service history.
CarFax data is absolute trash!!!
Yupster Dog
Moderator
Any data about a vehicle you are about to buy is valuable.
So Carfax, Car Check have valuable info when starting out your used vehicle search. You have to use it for what it is, The first tool to use for your search, So you don't waist your valuable time to go look at bad vehicles.
So what makes the data "absolute trash"?
Calidad
It’s easily avoided and nothing like the automaker info. Even my 93 Landcruiser data with Toyota was pages and pages of history the AutoFax showed one record ‍♂️
The G35x I was shopping for my dad 6 yrs ago. I found three with rolled back ODO not from Autofax but via a call to the dealer to check recalls and any service history. Its tough for a seller to explain why a car had 160,000-180,000 miles on it 4 states away after saying its a local car with 80,000 miles on it three cases not one Autofax showed enough info to determine questionable history. Phone call was free and way more info
2018ExpyPlatinum
Arizona
What's Autofax??? Carfax is usually pretty good, Autocheck is ok, but sometimes the info is lacking. It's a place to start. Best thing to do is to go to your local dealer and ask them to look at the service history via VIN. Most will do this and will explain what was done. An in person visit will usually get you the best info as opposed to a phone call. Some folks are very understanding and helpful. Some won't have the time of day for you.
SyndicateZ
Mass
Vehicles can be involved in accidents and then repaired ...depending on the repair facility carfax would never even know if not reported
dlcorbett
Air Force
tx
Our navigation maps. We updated to the latest ford/lincoln had to offer for Sync 3 like you did. Took well over 2 hours. It did seem to update some aethetics, the speed limit signs are more accurate to location(pre 22 navs don't have speed sign recognition so it doesn't update on the fly) but it still misses some road changes, exits and newer local streets.
Maxine the Max
South Dakota
my expedition changed speed limit signs, before the update. We don't drive in areas I don't know very often. So the navigation doesn't get tons of use. I was expecting the appearance to be different but it looks the same as it did before. I was worried updating might remove or change features but everything seems to be the same. Was that true for your navigator? I wasn't convinced it actually updated because everything looked the same. I forgot to take a picture of the sync version on the screen so I would know if it was different then before. I'm terrible at remembering numbers.
dlcorbett
Air Force
tx
The digital screen didn't change, the only thing that rele changed on the nav screen was the disappearance of the border btw the written directions and map.
As far as the speed signs are concerned, I didn't have it long enough to see it at different places, but locally, it's a bit more accurate to different sections of road, and on the highway, it changes old speed limit signs fairly quickly. However, our cx9 also changes speed according to road work as well and is slightly quicker in terms of changing to speed signs.
