Rear passenger window bounce back
Michael Holland
Northwest Illinois
I tried searching but didn't find anything. When rolling up my rear passenger window, either one touch up or manually, the window reaches the top and rolls back down about 8 inches or so. The only way I can get it all the way up is to bump the switch and hope I get it stopped in the full up position. It's pretty annoying. I don't have any history on the truck due to just buying it. Is there a programming sequence that can be done?
EDIT: 2019 Expedition Max Limited
Thanks in advance!
Thanks in advance!
You may want to post the year, make, model and trim line.
There may be a specific TSB or fix for a specific year.
SyndicateZ
Mass
Mine does that , sometimes, only when super cold outside and ice present on vehicle/window gaskets
GixxerJasen
DFW TX
Sounds like maybe some kind of calibration issue to set "Top" and it's hitting the top and thinking an arm or something is caught and rolls back down. Kinda like how you set the top and bottom of a garage door for opening and closing. Not sure how you'd do it but that sounds like the behavior and there should be a way to fix it I'd think.
harleytrike
pa
Do you have window deflectors maybe it needs pushed more into the window chanel.
ckaa
WA
My 22 is doing the same, but it’s the front driver window.
m3olsen
CNY
I don't have it memorized, but procedure is well documented, and changed for - I believe 22 - so 19 would be different. Check your owner's manual. Ford actually allows us to re-teach the bounce back points. It's some form of roll it all the way down, hold the button for x seconds, put it all the way up and hold it for x seconds, x number of times within x seconds. Should be fixable, without tools or a visit to the dealer.
GlennSullivan
Yorktown NY & Jupiter FL
Correct me if I'm wrong, but isn't the auto stop and auto retraction function a window motor load based function? I.E. window moving up, encounters a pre-determined motor amp draw telling it that it is all the way up and stops or window moving up and encounters a higher load at a sooner elapsed time than expected telling it that there is something blocking the window closure process, like a child's arm and the system then reverses the window closure process by "X" time.
If this is correct, then in each case there is something binding in the closure process - either in glass track or closure mechanism which is causing the reverse program to trigger.
GixxerJasen
DFW TX
Looks like this. Googling "Ford Window Bounce Back" returns a LOT of results on how to fix this with the proper procedure.
