Gas filler - no gas cap type
callwill
WNY
Have a 2011. It has the filler with no gas cap. What do people do to add gas if they run it down too far or out of gas(so far i have not but did twice in my ole 2002 when the gas gauge played tricks on me!) or put additives in the tank. I see how to open the "door" but no bottle of additives or gas cans i have will do it.
mr_dave
MN
You need funnel that's the same size as a filler nozzle. There should be one in your vehicle next to the jack, in the back of the cargo area. Otherwise you can get one at Walmart or any auto parts store.
m3olsen
CNY
I second @mr_dave 's comment. Your vehicle should have come with one. In with the jack, or for some reason I have seen them in gloveboxes at times in Fords.
Information on how to add fuel (or other products) is contained in your vehicle owner’s manual.
GlennSullivan
Yorktown NY & Jupiter FL
Here is what it looks like. 1 comes with each vehicle from the factory and is in the jack storage compartment, unless a previous owner removed it. If so they are cheap to buy online.
Ford 8U5Z-17B068-B Funnel
2009-2019 Ford 8U5Z17B068B
71Rcode
DFW Texas
I use a skinny funnel and a couple of screwdrivers to press in the tabs on either side of the funnel
purevw
Taking the chance of ruining the latch mechanism just to save $3 does not make sense. As stated, there should already be a funnel in the spare tire area. If not, they are super cheap.
jmdunham2
