2017 Lost Coolant!
mquick5
Buckeye Country
A few weeks ago I changed my oil & checked coolant level. Wife is main driver of this truck, she tells me the loud radiator fan was back. So I pop hood to see if coolant was low, the overflow was empty! I added around 3/4 of a gallon. 2 days later it needed another 1/2 gallon. I never seen any sign of leaking? A few more days pass, I discovered a large puddle under the passenger side of engine, and could see dripping, while truck was parked and not running. Overflow bottle still only down about 1/2". Since I have a warranty I took it to dealer, last Friday.
Dealer calls me within hours of dropping it off, asking me why I thought it had a leak? They tell me they see no signs of leak, and that its holding pressure? They decide to keep it over the weekend & recheck it. Well today I never get a call, so I decide to call them and see what's up. They apologize for not calling me sooner, and then tell me still no leak and held pressure all weekend. BUT, there's a lot of white smoke now!
So they went from no leak or problems on Friday, to finding internal leak today, but still not sure what it's from!
I’d bet your water pump is leaking while the engine is running.
Mine did - but the dealer claimed there was no leak when pressure tested.
I returned the vehicle and insisted they put it on a lift. The technician quickly saw the dried coolant residue near the water pump. The water pump was replaced under the Ford Premium Extended Service Plan.
mquick5
mquick5
Buckeye Country
Thanks for the reply. Isn't the water pump near center or drivers side? My leak was on the passenger side, i was thinking turbo cooling line? Also I wouldn't think the pump would cause white smoke out the exhaust? Dealer also claimed they had it on a lift, and seen no sign of a leak last Friday. Suppose to be having a better tech look at it tomorrow. I hope they get it sorted out quickly, as I leave for the Nascar race in Tn. weds and hate to leave the wife without her truck. Dealer did provide a Edge for a courtesy vehicle, but she's fun size, and really needs electric pedals to drive w/out being on top of the wheel.
Yes - water pump front and center.
I also had a left side turbo cooling line leak, although the leak was small (at a different time). I was covered under my Ford ESP and it is a labor-intensive repair.
mquick5
mquick5
Buckeye Country
White smoke means burning coolant. Have the dealership check the cooling system for combustion gas.
I've personally never seen it smoke. They went from no issues last Friday, to white smoke on Monday. As of now they still have no answer for me. I stopped by yesterday to retrieve my lawn chair for the race. I asked the service manager for a update while there. He told me there still waiting on there engine expert to look at it. So far today no call again. In fact they have only called me back 2 times last Friday, stating no issues found, and agreed to keep it the weekend to re check on Monday Am. I had to call them Monday afternoon, they did apologized for not calling, but gave me the white smoke news. I'm starting to loose patience with them...
JasonH
Houston, TX
I feel your pain. Bought my wife a Jaguar I-Pace. We've only had it for three days in the 4 weeks since we took delivery.
Anthony DeVor
My 2017 Expedition does the same thing, loses coolant out of the tank but no obvious signs of a leak. Mine does not push white smoke though. Please keep us/me updated as to what the dealer finds.
BlackBetty
Army
Surprise, AZ
Have an open mind when looking for a leak; very open mind with broad imagination. I had a leak under my vehicle on passenger side as well. Long story short… ended being the driver side coolant fitting on top of the turbo. Didn’t figure this out until I had the entire passenger side wheel well ripped out in preparation to pull the turbo so I could replace the fitting, and O-ring.
As I got in there closer everything looked clean and dry. Did find a flow path… followed it to the driver side. Crazy how that happens.
mquick5
mquick5
Buckeye Country
Okay well it was in fact the water pump! I guess it just took my dealer a week to figure it out. I've been busy with going out of state for the races, the wife picked up the truck Friday. I need to go out and look at it, as I'm not sure if the pump on these are internal or externally driven. If its internal and leaks that would make since to me, about the white smoke "that dealer reported". Also if it is a internal driven water pump, should I be concerned with any internal damage to motor, from coolant leaking through?
The engine water pump is externally driven.
Amazing how it took your Ford dealer so much time to find a leaking water pump.
I had the same problem with my Ford dealer.
I’m glad you’ve found the leak and had it repaired.
mquick5
mquick5
Buckeye Country
Thanks for information. The water pump being external, doesn't explain the white smoke the dealer reported. When I went out to look at the truck, the coolant overflow bottle appeared empty! IDK weather to just top off and watch it, or take back to the dealer for a week or so again?
Update: there was enough coolant in the bottle to see that they used GREEN! IDK if thats a big deal or not, but for some reason the manual says to use orange?
I know Motorcraft changed the recommended engine coolant for the 2015-2017 models. My 2015 was changed using the new coolant (color). I questioned the service advisor and was told there had been a changed.
Ford and its dealers should notify its customers (such as by the service advisor) or on the service invoice, when there is a change such as this.
mquick5
mquick5
Buckeye Country
What new color coolant did yours change too? Everything I read says orange, not green.
mquick5
mquick5
Buckeye Country
GlennSullivan
NY & FL
BTW Green has now been superseded by Yellow. Confirmed that with the dealer a few weeks ago. Ill post the latest MC part number when I go out the the garage.
