Global Window Open & Close
Pancho258
McALLEN, Texas
22 Timberline. So I can get the windows to globally open but not close. Went by my dealer today and they were no help.
what is interesting, if you read the manual it indicates Ho to menu from your steering wheel control and then go to settings. From setting you should have an option for windows. Nope does not exist. Go to the 15“ screen menu and look through every setting that is available, no window option as a choice.
Read the owners manual that is loaded into the system and view the details on Global windows. Here is where it goes off in left field. It comments about Global Opening but nothing about Global closing.
Does the truck only do Global opening now? Anyone else with a Timberline experience the same issue?
gural
Poland / Europe
Loki
in other topic i wrote
Hi
I have a problem with global open/close feuture
I went to forscan and putted on both options - both (0 - enable 1-key 2 remonte 3-both)
but it do not work
is there other thing that i should do??
BestRegards
You wrote that the
"Only way to activate it and add to the menu is via FORSCAN."
how can I add it to menu?? I got 2019 XLT
wakeboarder
Fort Lauderdale, FL
Loki
Hi
but it do not work
BestRegards
You wrote that the
According to the 2019 order guide, all expeditions have the one touch up and down feature for the first row.
Did you enable it in the BCM, PDM, and DDM?
Moderator
Based on the setting they quoted above they were in the BCM easy config options. So You might be on to something. Probably did not make all the changes.
gural
Poland / Europe
so basicly my XLT have a switch for 1 row
I did changes only in BCM (normal one not in AS BUILT FORMAT) becouse the funkcions are already there
I did not do any changes in other part
I seen YT for F150 that people were doing changes also in PDM AS BUILT FORMAT(1 row) and DDM AS BUILT FORMAT (1 row) but those are diffrent then My car got
So question (as i assume F150 vs Exp got diffrent soft) what changes extra should be done
gural
Poland / Europe
so i check once again - via normal interface not hex
BCM(Body Control Module) - option for open and close - 3 both
DDM(Driver Door Module) - option enable
PDM(Passenger Door Module) - option enable
APIM(What controls Sync) - Technically not a requirement, because it just turns it on and off - i do not have anything with windows in APIM module... - so no changes
and still not working
wakeboarder
Fort Lauderdale, FL
This thread should have more information.
gural
Poland / Europe
before i started to post in this topic i already read those 30 pages
but still no changes - > really i think i will let go
other upgrades i allready done
gural
Poland / Europe
Exploring the forum i found this topic
Global Windows- (OPEN)
BCM
726-11-01 change to xxxx-xxxx-x1xx,
726-11-02 change to x0xx-***-xxxx,
726-22-01 change to 0101-0101-01xx,
726-27-02 change to xxxx-x1xx-xx,
DDM
740-05-01 change to Dxxx-xxxx-xx,
IPC
720-02-01 change to 7xxx-xxxx-xx
(CLOSE)
BCM
726-11-02 change to xxxx-xxx1-xxxx,
726-22-02 change to 0101-0101-01xx,
726-27-02 change to xxxx-xxx1-xxxx,
PDM
741-05-01 change to Dxxx-xxxx-xxxx
I will try this and let You know it it works with 2019
but i see that there where made changes also in IPC
mdecillis
Iselin, NJ
Loki is correct as usual, you need to have the auto open/close ability in the car itself. And most likely that ability was removed from your rear windows in 22 like mine (chip shortage). I can only do the front windows and I believe Ford just turned global windows open/close off completely on the trucks that had the auto open/close removed.
gural
Poland / Europe
mdecillis
i got in my Exp auto switch for front (one click for driver and pass)
i do not have for rear
in Forscan in normal mode i can change it to enable (global windows putted to 3 - both in BCM, and i DDM i PDM to enable)
but still front windows do not open and do no close...
i dont care about rear becouse i do not have auto switch -> so i know they would not work anyway
dman3540
Mission Viejo
Hi everyone, I just picked up a '23 Expedition XLT and was trying to configure the global window option in Forscan. I see this was an issue a couple years ago, has anyone figured out a fix? I am able to program it to my '23 Bronco, but the Expy is being a little ******** about it. All global window options have been enabled in all 4 modules. Any other thoughts?
Thank you so much in advance!!!
Dan
