Global Window Open & Close
Pancho258
McALLEN, Texas
22 Timberline. So I can get the windows to globally open but not close. Went by my dealer today and they were no help.
what is interesting, if you read the manual it indicates Ho to menu from your steering wheel control and then go to settings. From setting you should have an option for windows. Nope does not exist. Go to the 15“ screen menu and look through every setting that is available, no window option as a choice.
Read the owners manual that is loaded into the system and view the details on Global windows. Here is where it goes off in left field. It comments about Global Opening but nothing about Global closing.
Does the truck only do Global opening now? Anyone else with a Timberline experience the same issue?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Only way to activate it and add to the menu is via FORSCAN.
gural
Poland / Europe
Loki
in other topic i wrote
Hi
I have a problem with global open/close feuture
I went to forscan and putted on both options - both (0 - enable 1-key 2 remonte 3-both)
but it do not work
is there other thing that i should do??
BestRegards
You wrote that the
"Only way to activate it and add to the menu is via FORSCAN."
how can I add it to menu?? I got 2019 XLT
wakeboarder
Fort Lauderdale, FL
Loki
Hi
but it do not work
BestRegards
You wrote that the
According to the 2019 order guide, all expeditions have the one touch up and down feature for the first row.
Did you enable it in the BCM, PDM, and DDM?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Based on the setting they quoted above they were in the BCM easy config options. So You might be on to something. Probably did not make all the changes.
gural
Poland / Europe
so basicly my XLT have a switch for 1 row
I did changes only in BCM (normal one not in AS BUILT FORMAT) becouse the funkcions are already there
I did not do any changes in other part
I seen YT for F150 that people were doing changes also in PDM AS BUILT FORMAT(1 row) and DDM AS BUILT FORMAT (1 row) but those are diffrent then My car got
So question (as i assume F150 vs Exp got diffrent soft) what changes extra should be done
gural
Poland / Europe
so i check once again - via normal interface not hex
BCM(Body Control Module) - option for open and close - 3 both
DDM(Driver Door Module) - option enable
PDM(Passenger Door Module) - option enable
APIM(What controls Sync) - Technically not a requirement, because it just turns it on and off - i do not have anything with windows in APIM module... - so no changes
and still not working
wakeboarder
Fort Lauderdale, FL
This thread should have more information.
gural
Poland / Europe
before i started to post in this topic i already read those 30 pages
but still no changes - > really i think i will let go
other upgrades i allready done
