Coolant leak
Tuck91410
new mexico
2017 Ford Expedition limited… I have a coolant leak but can’t see where it is coming from. Don’t know what to do so I’m at the point where I’m just going to start replacing water pump and thermostat housing.. Any ideas would be greatly appreciated
GaryH
Army
Just curious, but how do you know you have a coolant leak if you can't see a leak? I don't think its wise to just throwing parts at it. If the water pump or thermostat housing is leaking, it should be very obvious. Hopefully it's not an internal leak like a head gasket.
glockmeister
Fargo, ND
If you are low on coolent and do not see a leak, pull your oil dipstick and look at the level. Could be head gasket or cracked head and would not be a visible leak.
A common leak point is the water pump, which may only leak while the engine is running and the vehicle is being driven.
Based upon my experience and other posts on this forum, the original pump fails between 55,000 - 70,000 miles.
Dennis_H
DFW, TX
Mine (2010 5.4) had a leak I could smell, but not find. It was crossover pipe so it would pool on top of block and evap off, or leak if enough angle. Think the 3.5 has same type of crossover.
JimmyC
New Hampshire
Clean the engine, dry throughly then wrap a paper towel around like leak points, drive for a couple of days, you’ll find it
dkincaid32
texas
I'm surprised no one mentioned the turbos yet (super-common failure point). I have a 2017 as well, also with a coolant leak (maybe a pint every two weeks). Mine is leaking from the passenger side inboard turbo coolant fitting and there's moisture near the forward end of the crossover pipe. Its too hard to see without disassembly, but its either the thermostat housing or most likely, the forward O-ring on the crossover tube.
I'm amassing parts (got the infamous broken header bolt too) and awaiting on good weather to tackle them on a weekend.
jonj13
South Carolina
Check the hose connector at the bottom of the degas tank, they're a problem, the coolant line fittings on the turbos, also a common problem. My waterpump never showed any signs of leakage until the bearing failed and lost most of the coolant inside of a minute.
In addition to the water pump and a heater hose fitting, the degas bottle leaked on my 2015 Expedition Limited. All replaced by the dealer.
Michael Egerman
My 2017 is in the shop for a coolant leak that I could not find. We pressure tested for five hours as it was a very small leak. Eventually found a puddle under the left rear wheel. Turns out the metal coolant line to tg the rear heater was weeping at the aluminum crimp. Both lines are being replaced. If you have coolant level loss then do a pressure test.
fireman643
Kentucky
Just replaced my water pump 2017 3.5 ltr. It leaks and runs under the intake to the transmission and with the belly pan you never see it . My service guy caught it while oil change , it did have a little belt rattle when 2st started but I had chalked it up to cold .. anyway all good now !
andrade93
california
By any chance do you know if the water pump had a 3 hole hub or 4 currently dealing with this
NDspd
Cleveland, OH
I had a significant leak at the plastic/hose junction splitter in my heater core hose. Drip would run down the intercooler hose on the passenger side and then to the ground.
