Those who have Extended Service Plans (ESP)
37ford
Mississippi
Which plan level do you have?
Have you had work done that either wasn't covered by the ESP or wouldn't have been covered by a lower plan level?
My 2019 has 108K miles and has been a real pain in my side this summer. I'm going to get an ESP, and I'm trying to determine if there is anything that the "ExtraCare" doesn't cover that can be considered a typical problem with these cars. My gut tells me to just get "PremiumCare" so Ford can't try to pull anything over on me.
Boosted
North Jersey
For me, the PremiumCare wasn't too much more than the ExtraCare when considering how much more it covers. Shop around on Zieglers to figure out the differences.
37ford
Mississippi
Zeiglers is by far the lowest price, but there is a $400 difference in the two plans.
Going_Going_Gone
Phoenix
Got the premium care warranty from Flood Ford. So far I haven't used it, but it still has another 28 months of coverage, so there's still opportunity to get something for my money. If I had it to do over again, I would have opted for fewer miles and added lighting coverage. This is only the second extended warranty I ever bought. The first was on our early-build 6.0 diesel and we never had to use it.
BMW2FORD
CT
I went with the Premium care to get lighting coverage which was an extra $100 on top. Lights in these trucks are expensive, especially if you have the LED’s which are not serviceable.
SE Wisconsin
I just purchased my new to me 2021 max limited with 33k on it 3weeks ago and negotiated the 7yr 150k mile 100$ deductible premium care with the lighting option for it. After losing my transmission on my 16 tahoe ltz and 2 sets of struts, rear shocks, shark fin antenna leak etc over a 3yr period I didn't want to chance it. 8k for a new tranny alone was a tough pill to swallow let alone the almost 2400$ for each round of struts.. first time ever buying an esp. Chose to go with "better to have it and not need it" rather than needing it and not having it.
2018ExpyPlatinum
Arizona
Bought mine thru Anderson and Koch back in 2020?. 72months/75K miles. Don't remember what I paid, but I have never used it. Premium plan with lighting, key and rental. Like I've said, I think I got a good one with zero issues...ever. Starting to question if tranny issues are coming. At times, it won't up shift and the other day going down hill to a stop sign, it down shifted several gears causing it to rev high. Anyway, warranty expires in November. I'll either extend it for two more years, or buy something else....but what?
kwsutter
Rochester, MN
I bought the PremiumCare when I purchased a used 2018 Expedition. Nothing too major, but I’m glad I went with it. I’ve had to replace the rear console due to a faulty switch. Several TPMS monitors. And, a set of wheel bearings, which surprised me they were covered. I bought mine through Lombard Ford, which I thought had the lowest prices until I started reading these replies….
Fastcar
Army
FL
I have one and am in the process of using it for the first time, one week after the 36 month warranty expired. Rear evaporator went south, not a fun replacement.
srubin1090
Daytona Beach, FL
I have a 2019 and got the premium ESP in 2022 at 75k miles for $3810. I got the 60mo/48kmi plan with key, lighting and 3 year maintenance package from Lombard Ford. So thankful I got it when I did (after radiator hose leak/$900). The lighting warranty has already paid off, both of my headlights went bad and had to be replaced in the last year. I’ve had other random work done, the dealership does everything together so I only have to pay the $100 deductible for multiple service items. I definitely made a rash decision and bought a dud Expy but this ESP has made it all better .
My cat (or O2 sensors) are going bad, throwing codes every few weeks then disappearing, my rep said emissions isn’t covered under warranty so that’ll be $2-$3k out of pocket but that’s it so far for what hasn’t been covered.
SyndicateZ
Mass
Get the premiumcare with all option
My 3rd brake light has a few LED's out (about 40% out) im assuming by moisture cause I can see it in the housing. Do you think my premiumcare w/LED lighting option will cover a new replacement ? I can aee Ford saying that it needs to be totally out before replacing tho.....
Anyone ever have this same situation covered?
JamaicaJoe
Oviedo FL
They should cover it. The light probably does not meet intensity requirements with that many LED's burned out. It cannot be repaired by any means.
ManUpOrShutUp
I bought my Expedition as a CPO, which carried the Premium plan with it at the time. I had nearly $20k worth of repairs done in about ~25k miles with the vast majority of that being related to the Limited features. They replaced the climate control panel, all of the climate-controlled seat components, the backup camera, the entire power running board assembly on both sides, etc. They also fixed an oil pan leak, replaced 2 struts in the rear and replaced a couple idler pulleys. That's all I can recall off the cuff, but there might be some other things they did as well. I paid $100 per service visit (2-3 visits). In short, I would recommend the Premium plan. ESP pricing varies wildly though, so shop around (unless you're in Florida I suppose, where you pay out the nose no matter who you buy from).
Fastcar
Army
FL
Aren't cats and some other exhaust emission stuff covered until 80 or 100K?
GlennSullivan
NY & FL
Ive always purchased the Premium care warranty which is supposed to be as close to Bumper To Bumper as you can get, and in general has been money well spent.
I will say even with the Premium Care, Ford will try to weasel out of repairs.
A leaking positive battery terminal (known problem) on my 2017 wiped out the battery and positive cable - which is not a 2’ long traditional battery cable with terminal (battery and battery cable specifically excluded) but a 10’ long harness with 20 or so connections costing $400-$600 depending on the source, plus another $400-600 in labor again, depending on who is doing the repair.
In spite of the fact this failure was caused by known issues and the damaged item was clearly an electrical “harness” not a battery “cable” they refused to cover the repair.
So long story short, they WILL try to screw you, if they can.
I ended up purchasing a new battery (which failed again in 18mo but replaced free then) and sourced a new factory identical terminal which I crimped onto the end of the factory harness.
Left Coast Geek
Mid Left Coast
O2 sensors (and catayltic converters) are a LOT cheaper from an indepedent shop. just insist they use good parts, Ford or Motorcraft O2 sensors, and cats from Mangaflow or Walker. A gas analyzer combined with o2 sensor data logging should tell whether its the o2 sensors or the cats themselves. Hmm, looks like Mangaflow has direct fit cats for Expeditions, they claim 280219 (right) and 280218 (left) are 47 state direct fit.
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Repairable, probably not, but replacable, absolutely....there are numerous YT vids that show you how....
I know mine is an earlier model (2011, which are much simpler), but replacing the OEM 3rd brake light with $35 LED one took all of 5 minutes with a Phillips screwdriver...I also replaced all the headlights (low & high), turn signals F&R and brake light bulbs with LED's in about 30 mins :)
ManUpOrShutUp
100%. They lubed up my running boards 4-5x before they finally agreed to replace them. With my idler pulleys, I had to get out the stethoscope and be 100% certain that was the source of my accessory drive noise as they said if I was wrong it would be a $150+ diagnostic fee. Then with the rear struts, they insisted they were shocks and not covered. My independent mechanic said "Put the tech on the phone and I'll explain to him why those are struts." Ten minutes later after a lot of "uh huh, yep" from the Ford tech, he agreed they were struts and thus covered. It was always a battle with them though.
