Yep, new/rebuilt tranny at 40K miles
Jskane125
Pottstown, PA
So the hard bang I get intermittently when shifting Expy from park to drive was confirmed by dealer testing - and some rough transitions from 3rd to 4th gear (which I don't really notice). The dealer plans to rebuild or replace the transmission pending some additional testing. Parts are delayed for two weeks, putting a RV trip scheduled to start Aug 13 at risk.
Oddly, for the most part the transmission is fine - expect about 3 out of 10 times the bank from park to drive feels like it will pull the transmission apart.
Kind of discouraging, though at least my extended warranty (2020 Expedition) is still in place. Since that runs out in 2025, I asked if the new/rebuilt transmission will have its own extended warranty. I assume so, but will find out.
While they are going to give me a rental (they won't give a truck as a rental), I'm meeting with the dealer to discuss the possibility of them letting me use a truck on the used car lot for my 1 week trip, assuming that the parts won't get in on time. I've bought two cars there, and have had my Fords serviced there for 15 years - so I'll pull out the stops in asking for this.
After this fix I hope to get more than 40K miles out of the new transmission. Geez.
Deadman
How far are you needing to tow your RV? These trans don't usually stray you, they just shift like crap. I'd run it and let them fix it after the trip unless its super far......
RocketJump
CA
Thanks for sharing. My 2018 with 53K occasionally has similar issues, and some of the rough shifts out of park feel like they could snap a rod. Our friend's nearly identical Expy recently had a transmission replacement due to a spontaneous failure when on the road. Their repair took over a month.
wpaul
WV
I've had rough shifts as well mainly in normal mode and worse in Eco mode. I've since made a habit of always running in Tow mode and the hard shifts have went away entirely. I'm with @Deadman use it for your trip and let them fix it when you get back.
5280tunage
colorado
Just left mine at the dealer today for tranny stuff. The reassuring part was they said they heavy tech working on tranny's won't even be able to look at it for 2 weeks they are so backed up. Luckily, I have a decent loaner but this is absurd.
Ugh_J
Texas, USA
This has largely been my experience, and it makes me wonder if most of the shift roughness (aside from those directly related to the bushing and case-wear issues) at least on the pre-2023 models is related to the 1-3-5 shift pattern in normal/eco modes. While tow/haul and sport might be a little firmer, going 1-2-3-4-5 does make for less of an RPM drop each shift, and under moderate to heavy acceleration it is far smoother from a stop. I really wish we had open-source PCM/TCM firmware for these things.
Hellwig
Exactly same problem for my 2024. If I heavily brake it, it stops smooth. If I moderately or lightly brake it, it will give me a slip from gear 5 to 3 or 4 to 3. With my trailer connected and the tow mode, transmission becomes smoother.
Jettix2
Frankfort, MI
My '19 was reflashed and then rebuilt with new style CDF drum at 42k and now it's failing again at 56k.......tech verified, reflashed again, same non-sense, it goes in for repair/replace/rebuild on Sept 3.......
J
Jskane125
Pottstown, PA
Update: They told me today they replaced something, and will road test tomorrow. We shall see. The customer manager told me there is a low percentage of success within the three-four levels of fixing and testing. Short of a full rebuild. I didn't get a straight answer today on what they fixed at what stage/level. So I guess we'll see what happens.
Jettix2
Frankfort, MI
My guess is they replaced the valve body. Unlikey that’s gonna fix it. Even my CDF replacement “rebuild” only lasted 10k miles before it acted up again. I told the SA I want a factory new or factory reman transmission, not one rebuilt at the dealer. She agreed and is going to fight for it.
5280tunage
colorado
I just don't understand. there are class action lawsuits for dumb stuff every day, but how come we don't see more for these things. mine is at the dealer, now going on 10 days, and hasn't even been looked at yet, for tranny issues. The number of issues we see, the number of repeat fixes and repairs, heck the dealer said their tranny tech is running 2-3 weeks behind on projects so it's clear these things aren't working. how many millions of lost hours are we all putting forward on these things, and yet they keep going up 3-5% / yr. I'm not lucky enough to have 4 cars, so having our primary family vehicle in the shop for 3-5 weeks isn't acceptable.
it would be one thing if there were tons of choices, but for class of vehicle like this, there really are only two choices and they both appear to be having record quality control issues (and yeah, both american made). Having said that, even the Toyota's of the world are experiencing massive issues as well.
But the two biggest ones we see impacting folks every day on here, tranny and phasers. these are very well-known issues that so far seem to only have temporary fixes, high numbers of re-repairs. and sure, we all know people mostly only come to forums like this to talk about problems so we could say there's a lot of happy people out there, but along those same lines I would be the majority of drivers out there have no idea they may have issues (and worse don't pay any attention) unless the car tells them so.
J
Jskane125
Pottstown, PA
Last update. They did a full rebuild of the transmission. Interesting to follow. They had to go through three sets of activities first. Each step was a "fix" of sorts. And the tech, whom I met, documented results for each test. The main control valves were sticking, with valves stuck in their bore and not moving during gravity test. Ended up a transmission overhaul per TSB 24-2101. They rebuilt it, had three road tests, which also served to support the transmission adaptive learning. Seems to have been very thorough. I did't ask, but I believe the new parts address part of the problem in the original parts.
Anyway, I drove about 50 miles, and the difference is fairly obvious. Smoother shifting, no clunks when shifting to drive or while driving. This was all covered at no cost as part of the original drive train warranty.
So I'll be driving the RV about 300 miles each way for a trip this weekend (though I intend to drive a bit more before that). Hopefully, all will be well.
Good luck to those of you struggling with poor transmissions. I'm pleased with how my dealer handled it all. I hope you have the same luck.
5280tunage
colorado
Did they do all of the tests during one visit? One issue I've had in the past is the usual we'll try this fix, then you drive it for a week till it happens again and then bring it back, which wastes massive amounts of time and is extremely intrusive.
I'm still blown away with the issues we see with these tranny's below 60kmiles.
Jettix2
Frankfort, MI
Agreed. the lag time in between repairs PLUS the fact that my dealer is 6-8 weeks booked out between appointments make this crazy.
bocabimmer
South Carolina
I must’ve found the right dealership then… took in yesterday, they diagnosed the CDF within hours and got Ford to approve the repair under my ESP. They have the parts but a week’s backlog for the technician. They’re giving me back the truck to use and will call me when they’re ready for me again.
Considering all the horror stories I hear on here, this has been the 100% opposite of what I was expecting.
MHEXP
So Cal
2020 - rebuild at 41K . Started with hard shifts. Then while driving if needing to speed up it would drop to 1st and rev high and not respond then sam into 3 or 4th gear and give power back. Started doing this and first step was a refresh. Been good for most times. Found Sport mode works to skip most issues. Until 51K on freeway the other day and it started to slow for no reason, looked and saw trans temp had redlined and then dropped to first... could not go more than 20miles an hour. Sketchy on the freeway. Got off and let cool down. Restarted and limped home for 50 miles. Going in Monday for rebuild number two or full replacement. Will see what happens
I’d bet Ford will not approve a full replacement - but will require a rebuild by the dealer.
Let us know what happens.
SyndicateZ
Mass
Thats awesome that they are going to let u drive it until they are ready for it and they diagnosed the cdf drum quickly. Sounds like a good service dept. Good luck
