AC after Hose replacement
BlakeMAX2019
I had the Y-connector heater core hoses replaced at the dealer last weekend. The next day, I noticed the air conditioning wasn’t as cold as it should be. At first, I thought it might be my imagination, but after driving it yesterday, it’s clear that it’s not blowing cold air. It seems to blow cooler when I first turn it on, but the air gets warmer as it runs.
I’m wondering if this is just a coincidence or if it could be related to the recent work. Could it be low on Freon, or is it possible something was damaged or affected while replacing and testing the hoses?
Bmac1955
Southern Cali
Check to see if your belt didn't spin off. If it didn't , check to see if your compressor clutch engages.
BlakeMAX2019
BlakeMAX2019
Curious to what you found? Did you revisit the dealership?
After getting the two Y hoses replaced, I took the car home and, as I always do, checked the work. I noticed the coolant reservoir was almost empty. I took it back, and they told me the system “burped,” which they said caused the drop in coolant. However, I think the system should have been fully burped when the original job was done. Since the hose repair, the AC hasn’t been working properly. It’s not cold—sometimes it starts off cooler, but as you drive, it’s only slightly cool. The AC on this vehicle has never impressed me. I have only Toyotas to compare it to, and my 20-year-old Toyota with 240,000 miles still has an AC that can make the car feel like a refrigerator, and I’ve never even had to recharge the Freon. People actually ask me to turn it up because it’s too cold.
2018ExpyPlatinum
Arizona
Ditto. I've been saying the exact same thing for 5+ years. I think it's terrible. I run mine at 68-70. It's OK. My wife's 9 YO Rav4 is down right cold at 75, and cools quickly. I've had it checked and everything is "normal". Can't wait for the stop sale to be lifted on the Grand Highlander and the TX.
Bmac1955
Southern Cali
I live in S Cali and have a 2019 Expedition. A/C blows very cold. Temps here have been 100+. You might check to see if yours had a hose missing for the A/C drain along the firewall. Some were missed in production assembly in 2019. If your not cooling properly you have other issues going on. The only way to tell is gauges to test freon level. If it is very low on freon you may have leak in the system. That takes many steps to confirm that. Good luck. Many scenarios that could be the cause of your problem.
2018ExpyPlatinum
Arizona
@Bmac1955 ....I've had mine checked multiple times by two different dealers. Everything is "normal" or "operating as expected". The usual dealer lines. I don't drive it a lot in the heat, so I'm kinda over it. It's just frustrating. I'm sure if I rolled in there without a warranty, it would be fixed. I just know it's not right.
bryz_expy
Denver, CO
I'm following this thread because mine is going in next week for Rear AC blowing warm. Front blows cold.
But I did recently replaced the Y fittings, this weas 4K miles ago. I think mine might be the rear evaporator, but it is a slight coincidence.
BlakeMAX2019
BlakeMAX2019
Interesting as I did some common sense detective work and ours works better if the rear is on. If the front is on by itself, it blows cool air not cold, as soon as we put the rear on both blow colder good but not great. Weird.
Bmac1955
Southern Cali
Weird.....although, I let my rear run on low all the time. I get annoyed at times because the rear vents close by themselves which means I have to open the diffuser to get sir out of them.
BlakeMAX2019
BlakeMAX2019
Thank you! I’m in Southern California as well. I checked to see if that elbow was on the firewall, and it’s not. I appreciate you pointing this out. Now that you mention it, I don’t think I’ve ever seen condensate draining from the car, though the front passenger floor isn’t wet. I’m wondering if this could be affecting how cold the AC blows.
Interestingly, this past weekend, the air conditioning was working very well, blowing cold air. Both the front and rear AC were on at the time, but if we shut off the rear AC, the front stops blowing cold. If we run the front and then turn the rear AC on, you can actually feel the air getting colder.
BlakeMAX2019
BlakeMAX2019
Me as well, never was impressed by the AC of this vehicle… But I am comparing it to my Toyota. The new Grand Highlander is great… I’d need the new sienna due to the fact that we have five kids and need the room. It has the same drivetrain and MPG. The only thing I don’t like about it is the leaf blower engine that they put in it… Sounds very unrefined and loud.
BlakeMAX2019
BlakeMAX2019
Found nothing yet… Except on the previous thread that I mentioned that elbow on the condensate drain is not there. I did go to the dealer today in person because it’s very challenging to actually talk to someone there and explained to them the situation. They said it could possibly be related to the replacement of the Y connector hoses or it could not they’d have to look at it obviously. The issue is it’s a total pain because they need it for at least a day
Bmac1955
Southern Cali
That condensate 90 elbow is a TSB campaign . I had mine installed by Ford covered by this TSB 2 years ago. I showed the service tech the TSB and they took care of it N/C. It was missed during build. Ironically, the port for drain is open and to me let's hot temps from the engine compartment into the plenum which not only create frosting ( Maybe ) but leakage when defrosting into the passenger side carpeting with moisture......
Bmac1955
Southern Cali
I believe that TSB 20-2170 for the hose for the evaporator drain. I had that repair or intall done 6/23.
BlakeMAX2019
BlakeMAX2019
Interesting, I’ve never noticed any wet carpeting. As I mentioned I’ve seen any condensation dripping from the front of the car…wonder why? And if condensate builds up in the line, would that cause the AC not to perform right? Who knows, we’re just trying to limp it along until we find another vehicle.
BlakeMAX2019
BlakeMAX2019
UPDATE: went to dealer in person yesterday, they said the issue may or may not be related, wouldn’t know until they look at it. Which is understandable.
Also…this past weekend, the front air conditioning was working very well, blowing cold air. Both the front and rear AC were on at the time, but if we shut off the rear AC, the front stops blowing cold. If we run the front and then turn the rear AC on, you can actually feel the air getting colder. Wondering what that could be?
