If the only way to rate the peak HP at a higher RPM would be to re-tune so the peak torque occurs at a higher RPM. (Hp = Torque x RPM)
The 2500 RPM torque peak is low compared to other engines except diesels. I think the GM Vortecs peak torque is around 4000 RPM.
Low end torque gives more throttle response and towability. But, you don't get that strong mid and high range pull when you stomp on it. The X has a great low end, but that's about it.
