Hey folks, found this thread since I'm working on what seems to be the same issue on a '05 Expy. I've already replaced the fuel pump driver module (the old one was corroded, but not all the way through) and the passenger side fuse box. Replacing the driver module did nothing. Immediately after replacing the fuse box the truck fired right up and ran great for 2 days, then left me stranded; cranks just fine, endlessly, but does not fire. Original code was P0191 fuel rail pressure sensor circuit range/performance, but that is not there now; no related code at the moment. Tow truck driver was great late last night and got this thing into my (heated) garage! Where should I be looking next?
A couple tests after I first posted:
Green and yellow wire coming from fuse box:
1) Has 12v on it when I turn on the key, still there when cranking
2) Unplugging and running 12v directly to it from the battery, still cranks but won't start
I guess I'm heading to the driver module to do some testing there next...
OK, so I removed the connector to the driver module and jumpered each of the 2 end pins:
1) Verified 12v on the jumpers when the key is on
2) Still cranks but won't start
I guess I'm heading to the fuel pump??? Is there something I can look at before dropping the tank? I don't have a pressure gauge and I'm not sure if there is even a place on this '05 to attach one.
