here are the picturesWhere are you seeing these payload numbers
That CCD comment increasing payload capacity is BS IMO. My 22 XLT has the standard suspension with the heavy duty tow package and I'm at 1795 lbs of payload. It is similar to that XLT truck except I don't have the pano roof which takes around 150 lbs of payload. The XLT should have around 1650 lbs payload IMO. I don't believe they made any suspension changes between 22 and 24 model years.The dealer sais
"As for the difference in payload between the XLT you reached out on and the Limited’s I’ve sent your way, the Expedition Limited has a continuously Controlled Damper with Sport tuned suspension. This electronically controlled suspension gives us the improved payload capacity. "
Is this the CCD W/SUSP ROAD PREVIEW 1,245.00 I see in the window sticker of the Limited model?
I have looked at about 8 New 2024 XLTs ( Non Max). they are all 1403 to 1405That CCD comment increasing payload capacity is BS IMO. My 22 XLT has the standard suspension with the heavy duty tow package and I'm at 1795 lbs of payload. It is similar to that XLT truck except I don't have the pano roof which takes around 150 lbs of payload. The XLT should have around 1650 lbs payload IMO. I don't believe they made any suspension changes between 22 and 24 model years.
Maybe they sent the wrong payload sticker for the XLT one? Have them resend it with the VIN sticker above it like was done on the Limited one so you can see the VIN matches.
Not for me.Does this help????
2024 Expedition TRAILER TOWING INFO
According to Ford the Expedition XLT payload is 1,757 to 1,827 lbs. Where are you seeing 1405lbs. Are you referring to an F150?Not for me.
I am trying to figure out why no new 2024 XLT goes above 1405 Payload.
Where are you seeing this? As I showed in my previous posts all the stickers I am seeing for the 2024 expedition are 1405 lbs.According to Ford the Expedition XLT payload is 1,757 to 1,827 lbs. Where are you seeing 1405lbs. Are you referring to an F150?
Ford's Website. Specifications.Where are you seeing this? As I showed in my previous posts all the stickers I am seeing for the 2024 expedition are 1405 lbs.
I saw the same when browsing on Autotrader a few weeks ago, where the dealers included actual photos of the sticker, they all had the same payload number. I as looking at limited with excursion packWhere are you seeing this? As I showed in my previous posts all the stickers I am seeing for the 2024 expedition are 1405 lbs.
So what are we saying here, all these stickers are wrong? the only way to know payload is to weight the car and subtract from GVWR ?
