Can we talk HD Tow one more time?
AJ82
The dealer sais
"As for the difference in payload between the XLT you reached out on and the Limited’s I’ve sent your way, the Expedition Limited has a continuously Controlled Damper with Sport tuned suspension. This electronically controlled suspension gives us the improved payload capacity. "
Is this the CCD W/SUSP ROAD PREVIEW 1,245.00 I see in the window sticker of the Limited model?
That CCD comment increasing payload capacity is BS IMO. My 22 XLT has the standard suspension with the heavy duty tow package and I'm at 1795 lbs of payload. It is similar to that XLT truck except I don't have the pano roof which takes around 150 lbs of payload. The XLT should have around 1650 lbs payload IMO. I don't believe they made any suspension changes between 22 and 24 model years.
Maybe they sent the wrong payload sticker for the XLT one? Have them resend it with the VIN sticker above it like was done on the Limited one so you can see the VIN matches.
jjscsix
texas
I just looked at the sticker on our 2023 Platinum. It is 1616.
It is the short (non Max), rear drive, HD Trailer package, 22” wheels, Panoramic Sunroof, CCD.
This is just for reference as another data point. BTW, Im noticing that a few posts don’t say whether they are Max or not or rear vs 4 Wheel drive
rnazer83
Canada
I have looked at about 8 New 2024 XLTs ( Non Max). they are all 1403 to 1405
Hellwig
I believe Ford factory workers just use whatever sticker nearby, with numbers in a certain spec range, when they assembly the vehicles. The payload sticker on my 2024 XLT max black accent with HD tow, 4x4 and with no sunroof tells me the rating is 1537lbs, which is completely ******** to me. I take it as such: anywhere from 1500 to 1700lbs should be fine.
rnazer83
Canada
And here is another 2024 XLT (Non Max) with No Pano roof and it is still 1405. I have yet to see a 2024 XLT (Non Max) higher than this.
2024 XLT - Window sticker is on the first page under the price of the listing - Door Sticker
AJ82
Not sure what is going on. The GVWR and axle loadings on that last one are pretty close to the same as mine with a significant reduction in payload somehow. Maybe Ford is trying to up-sale people to higher trim levels so they put low payload stickers on the XLTs. Or they do what Hellwig said above. I think Dodge was doing something similar to that with the Durango's where they all had the same payload regardless of the options installed. Downside is that is the "legal" payload capacity you are stuck with.
Buy an older one with a correct payload!
rnazer83
Canada
According to Ford the Expedition XLT payload is 1,757 to 1,827 lbs. Where are you seeing 1405lbs. Are you referring to an F150?
Where are you seeing this? As I showed in my previous posts all the stickers I am seeing for the 2024 expedition are 1405 lbs.
Fizzy
Alberta, Canada
As per @Mr Big 's link: Make sure vehicle payload (reduced by option weight) will accommodate trailer tongue load weight and weight of passengers and cargo added to towing vehicle.
With all the seemingly random/close payload numbers on the stickers, I would not be surprised if they weigh each vehicle as it rolls off the line, and a printer makes the sticker unique to that vehicle. That way the sticker is 100% accurate according to the DOT rules.
grwilson
California
I saw the same when browsing on Autotrader a few weeks ago, where the dealers included actual photos of the sticker, they all had the same payload number. I as looking at limited with excursion pack
rnazer83
Canada
So what are we saying here, all these stickers are wrong? the only way to know payload is to weight the car and subtract from GVWR ?
Hellwig
I agree. The GVWR on the sticker of my vehicle is 7720. The gross weight of the vehicle (no passenger and cargo) plus fuel weighted 5820 lbs on a CAT scale. Payload 1900 makes sort of sense to me for a XLT Max. Sticker payload number, 1537 lbs doesn't make too much sense to me. That's why I take it as it should fine under 1700 lbs payload, with a couple of hundred pounds as the buffer.
