Vehicle suddenly started vibrating like hell overnight
Ckeough02
Memphis
Hey guys, I'm having some issues with my 02, it started vibrating like crazy, no check engine light, it wasn't doing that the night prior when I got home, I'm unsure of what could've happened in the 12 hours to cause that, already checked my oil and transmission fluid and they're good.
I'll try to answer any questions y'all may have, I may try to run it to the shop later tonight
The engine is vibrating while running, and vehicle stopped?
Or, the vehicle is vibrating with the engine running and the vehicle being driven?
C
Ckeough02
Memphis
Hey! It was vibrating while running, did not stop/stall, I did limp it to a shop, and the check engine light came on and started flashing, which turned out to be a misfire according to the OBD2 scanner, it just took a couple miles of driving for the computer to register I guess, its getting worked on now, thanks!
jr1under
Aiken, SC
Thanks for posting an update, let us know what the shop did to fix it. From my limited experience, that sounds a lot like an ignition coil or spark plug gone bad.
