JamaicaJoe
My 2001 Expy 97K Miles has been sitting idle for quite a while, about 15 months with a run up every couple months. This week I decided to get it ready to sell so I went to start it and it seemed to be misfiring. I was not surprised because it has been raining and very damp. The thing is, it has a ton of pep and just seems to stutter when above 1100 to 1500 RPM. The Check Engine Light is not illuminated and I scanned for Mode 06 and there are no misfires being tallied up. Weird, because I usually expect that, and then shut it down and let it dry out (wet fouled plugs), but it is not doing that, it is not the usual misfire with awful bucking. Nope, it is stuttering under load and no codes. So I was reminded that the MAF sensor could need cleaning. That made sense so I bought some MAF Cleaner (CRC) and cleaned the MAF in-situ. It is a ***** to unplug the cable so, yeah I put paper towels under the inlet cone and sprayed away front sides and rear. No improvement whatsoever. I pulled the connector to the IAC Solenoid and the idle dropped way back so I assume it is not the problem.
I should note that bad fuel was a consideration so I added 6 gallons to the existing 5 gallons and threw in some HEET. It seems it was running just fine a few weeks ago, so odd that the fuel would go bad very quickly. The fuel pump was changed about 12K miles back. No hard starting, primes quickly.
Any troubleshooting thoughts for tomorrow afternoon? I really want to get this girl sorted out so I can sell it.
