2025 Expedition Max leveling
Devildog25
Missouri
Has anyone leveled their new Expedition? Do you recommend using a leveling block? Or do the cause damage? Is switching to coil over and a new upper control arm a better option? Never done a level kit before and don’t want to destroy the front end but would like to level the ride height. Thanks
I’m curious.
Why do you want to level the ride height on a new vehicle? Do you feel the vehicle is higher or lower in the front? What do you hope to accomplish? Can you feel the vehicle is not level while riding in it or driving it? Are you concerned with voiding any of the new-vehicle warranty by modifying it? Are you concerned that modifying the suspension will alter the ABS, stability control or automatic braking systems?
iaazan
Phoenix
My only opinion is that if you're lifting the front it'll make it look closer to the "don't skip leg day" trucks you see, in between the lift install and waiting for new tires. Better to lower the rear to level it out.
Putting lift blocks on will change the angle of the CV joints compared to intended normal angle. Maybe a little more wear and tear, will need a realignment especially for the camber angles. I lifted my jeep cherokee that way and the biggest issue is inspecting my CV boots for tearing.
