2024 Stealth Performance Package Sway Bar Upgrade?
BigKisKewl
Dallas, Texas
Hello,
Been looking at Sway Bar Upgrade for my 24 SPP.
When I started the research on this, I couldn't find if the sway bar was upgraded or not on the SPP.
And IF the Hellwig would be Better ;)
From Ford Parts I found this for my VIN.
Part #NL1Z5A772A (This is one listed for my VIN)
Weight: 10.4 lbs
Anti Swaybar. FPV SPORTS Suspension.
With Heavy Duty Suspension or Rough Road Suspension.
  • 01/18/2022 - 12/11/2024, Expedition (U553), With Rough Road Suspension
  • 01/18/2022 - 12/11/2024, Expedition (U553), With Heavy Duty Suspension
  • 01/18/2022 - 12/11/2024, Expedition (U553), FPV SPORTS SUSPENSION
But if I search a normal Limited. I see this part number also.
Part #JL1Z5A772A
Weight: 9.5 lbs
Anti Swaybar. Suspension Road Previewith CCD Suspn.
With Sports Tuned Suspension or Standard Suspension.
  • 01/18/2022 - 12/11/2024, Expedition (U553), With Sports Tuned Suspension
  • 01/18/2022 - 12/11/2024, Expedition (U553), With Standard Suspension
  • 01/18/2022 - 12/11/2024, Expedition (U553), Suspension Road Preview/CCD Suspn
So, with that, I tried to find them on ebay or more details on the SIZE of the bar, but could not find much.
If anyone knows if the "Hellwig 7688 7/8" " is bigger than the NL1, please let me know. I need to get under the Expy and measure ;)
Thanks!
Fastcar
Army
FL
I installed a Hellwig on the rear of my 2017 Limited EL. It made a huge difference in corning and curves.
Two different suspension set ups. The front bar is a beefy piece. I have CCD and am able to throw into curves a bunch harder than the KR. I'm not autoX with it but I'm more than satisfied with it and didn't feel that swapping the sway bar was worth it. If I could find one. But......ymmv
johnn8462
Illinois
I have a 24 limited max with ccd and my stock rear is the same thickness at the hellwig. Shouldn't the hellwig be thicker or is it just stiffer some how?
BMW2FORD
CT
Hey all, one of the things Ford does is change how hollow the bars are but the OD thickness is in many cases stays the same.
See below, this is a pic of a rear Navigator sway bar and at the top of the pink sticker it says it’s 20mm thick. The unknown is how hollow or what metal it’s made out of. For the fronts of Expeditions and F150’s, there’s up to 4x bars and the last letter is the only thing that identifies the difference. This is a B bar so it’s a little stiffer. A is usually the softest and most hollow with some vehicles going up to the letter D and in many cases with AB, AC in between but the OD diameter is the same.
Moderator
Hey all, one of the things Ford does is change how hollow the bars are but the OD thickness is in many cases the same.
This. Thickness is not telling. Internal makeup, and the stiffness of the actual metal composition matters more. Most replacements will be the same OD as stock, to fit in the same location with the same clearances.
Bmac1955
Southern Cali
I had front and rear swaybars replaced in 2024 with Hellwigs with end links. Expo xlt 2019. Independent shop. Took old parts with me. Decided afterwards rather than having them in my garage I took a sawzall to them took fit in my trash tote. I guarantee
they are not hollow Perhaps material used in manufacturing could be used for flexing. My opinion. I realize this is an old post, but I thought I would offer some input. BTW. The new Hellwigs did absolutely change the ride.
ThwopKing
Bunker hill, WV
And you did both front and rear correct?
Bmac1955
Southern Cali
Yes I did both along swaybars with end links. Also did front and rear shocks with Bilsteins. One front and one rear leaking. Didn't want Motorcraft shocks due to early failure of those.
