2026 Wiring Diagrams
Medictrode
NJ
Hello all,
I was curious if the 2026 Expedition wiring diagrams were available anywhere yet. I checked with AllData and don't see them listed. We just got 3 new Expeditions for our Medic trucks and I'd like to make a few changes, but having the wiring diagrams would be helpful..
Opinion: WTF was Ford thinking with the dual tailgate setup?!?!? This is the dumbest thing I've seen in quite a while, and it's going to inhibit us getting our gear out of the truck a bit more. Also, a lot more to go wrong. And the square steering wheel....I'd love to meet the dork engineer who designed that thing..
Hello all,
Why did your organization buy three new Expeditions if the tailgate is not suitable for your gear?
BlackBetty
Army
Surprise, AZ
I'm guessing the people with the wallet have no idea what's needed by the experts!!!
Also, did some research for you on the wiring schematics... note available using my resource at this particular time. A little too new for my go to place. I've got access to every make, and model. Even some overseas stuff. Also have tractor, and small engine info as well. Unfortunately, none of that helps you.
All that said, the newest found was 2023. Take a look, and compare to see if the wiring, colors, and components are compatible. Good luck.
caplanm
Boston
Hello all,
The Ford wiring diagrams are available thru a subscription to Ford's PTS Subscription (https://motorcraftservice.com -- choose Service Info from the top menu) or I'm pretty sure that the wiring diagrams are bundled with the Service Information CD/USB Stick on Helm Inc. (https://helminc.com), but you should check before you order. The PTS subscription is a bit pricey, but it gives you real time access to the full Workshop Manual, Wiring Diagrams, and other items such as TSB's/SSM's. The PTS covers all Fords from 1994 to the present, and all models. If you have a fleet of Fords, it might be worth the expense.
