Looking for mod suggestions
ka3nxn
Charlottesville,VA
Hi Gang,
I have a virgin 99 Expedition AWD with a 4.6 Triton engine in her. I would like to to pep her up a little I'm looking for recommendations.
Black_Exhaust
38cc Trick Flow Twisted Wedge Cylinder Heads, .6/.6 crane cams, some new valve spring, titanium rods, manley flat top pistons... Oh you said a Little pep... You can't go wrong with a flash for the ecu, predator or superchips are all I've ever dealt with and I'd recommend them.
Newport News, VA
^^^^great if youre rebuilding the engine...but to ball on a budget...exhaust, programmer, intake or gots mod, tps senor adjustment
jacks3am
michigan
It all depends on your budget, but maybe the gotts mod, a tuner. but if you want real horsepower throw a supercharger on it, 4.6's can take boost
tbake
K&N Filter, GOTTS Mod and exhaust would be the first 3 easy and least expensive...and you will feel like your driving a different vehicle just by the sound of it.
jacks3am
michigan
The programmer and gotts mod is the best bang for your buck, the tuner can add 10-30hp and the gotts mod increases throttle response......maybe tuner, gotts mod and then a larger throttle body so you can get the power to the ground quicker. I would say the programmer is the best bet for a noticeable increase.
The 4.6 you have is the PI if im thinking correctly so if you did a programmer, gotts mod, larger throttle body and an exhaust you should be able to stomp non PI 5.4's and 4.6's
http://focus.c-f-m.com/90-95ford46l-2v-97-034654lf150andexpedition75mmpowerplusthrottlebody.aspx
http://www.4wheelparts.com/Performa...74&t_s=33&t_pt=3169&t_pl=101445&t_pn=EDG85150
http://www.fordfullsize.com/forum/f75/how-gotts-mod-2215/
Or if you have deep pockets ..... http://www.turbochargers.com/store/product_info.php/manufacturers_id/47/products_id/1621
toms89
technical advisor
MD
Mines a non-PI 5.4. ?!:rolleyes:
toms89
technical advisor
MD
TFS is trick flow right? lol those are probably much better then the PI heads lol!
Yes Trick Flow heads.:)
I agree with what everyone else said above. But I don't believe ring and pinion gears were mentioned. A higher ratio can significantly improve performance. Unfortunately with 4wd it can be a bit more expensive as you have to do both the front and rear differential. If I had a 2wd expy it would be one of my first mods.
jacks3am
michigan
I was thinking about saying somthing but for the AWD you have to go all in and thats close enough to costing as much as a supercharger:eek:
OK not as much but its more then a programmer and such lol
