Tranny Question
royalet
MD
Got a 98 expo, 5.4L, 4wd, i had a tranny installed and the truck runs fine, but the issue is that when you move the gear selector, its not locking where it should be, for example, i place the truck in start, i have to go a little pass the (D) gear and then I am in drive, and then if you move the selector back a little it locks in. Any help appreciated
R
royalet
MD
Can the gear shifter on the collar on the steering whell be adjusted, this problem occured after my trans was installed
R
royalet
MD
still messing with it, its funny because it looks like it may be out of sync, on the shift you have P R N D 1 2 , the furthes i can shit the shifter is 1, i have no more room, because the shifter is at the end of the steering coloumn
JUST4FUN
Admin
Moderator Administrator
Il
dont you neen P R N D 2 1 AND IT WILL ONLY GO TO THE 2
green03
College Station, TX
The cable needs to be adjusted on the driver side of the transmission. It's pretty easy to figure it out. Don't keep driving it like this. Take it back to the shop, if you drive with it between gears it can damage the trans depending on how it is set up.
Matt
No members online now.
Landsbutter
