SourMashII
I have conflicting reports.
DPTuners in North Carolina telle me for $75 (reflashing fee)
they will create a PCM that has the PATS killed, and will have the speedo pick up its signal off the Pumpkin ABS VSS.
As well as curing other "incorect" parameters created by my manual swap.
Speed-O-Motive in Fruitland, ID.. claims to work with everything from a Focus to a 6.7 PSD, says that is incorrect information, and for $425, they will rewire my truck, to have the former VSS transmission input for the speedo, read off the PCM's input from the ABS tone ring.< He (Speed o motive) made it sound more complex than just switching input designation in the PCM, as DP said it could be done, SpeedO also claims to correct any driveability issues, write the performance tunes, and kill the Emissions readings, so that it will pass smog, and be able to support free flowing exhaust. e.g 2 or 4 cat delete.
Wife had sticker shock at the second, and then I googled PCM tuning software.
< I need to do that to this truck to show it who the daddy is, and make it
