proper inflation?
TobyU
Ohio
Not co
I run mine at 35 PSI max. My previous Ford I'd run at about 32 PSI for 16 years.
The more pressure you put in tires, the harder it will be on suspension components. Whatever fuel you'll save by running high pressure will be pissed away every time you'll have to do a ball joint, strut or wheel bearing prematurely.
Now, I'm not too familiar with the skinny tires on large mags (never had them, never will), but I believe these will require higher pressures by default, as not to damage the rim on every pothole. These types of wheels really do a number on the suspension components, though... especially on a big & heavy truck.
Not completely true for front end parts. Low tires give more turning resistance especially at slow speeds and parking lots. Low tires put more strain on inner and outer tie rod end and idler and pitman arms and steering racks too.
TobyU
Ohio
Here we go again.
Most of the time if you put the placard or 35 psi in a E range tire it WILL look low....BECAUSE IT IS!
It was not made to put on a standard load vehicle and have 35 psi in it.
The manufacturer recommendation ONLY considers the original size and load range NOT a D or E.
People keep spouting the OEM pressure as correct but it IS NOT if not the OEM spec tire!
Often 44-45 will look ok and get you by but I find at least 58-50 in an E tire but most ride best at 60-70.
I put at least 60 in all E range tires. If they are on a vehicle that carries heavy loads then they get at least 72...80 if the vehicle is loaded to capacity often.
IF you are not loading it down then the best way is the chalk method.
You have to draw a line across the tread and drive to see what inflation give you the mose even wear across. This will give you the best contact patch which will be best balance between wear and traction.
NOW IF you are carrying heavy loads, the ability of the tires to carry the weight and not blow out or separate and tear belts is more important than the contact patch or wear....SO more air.
P
Plati
When I first went to E tires … based on discussion and advice on this Forum … I did a bit of research and found some documentation (cross reference table) from something like "The American Tires Manufacturer Association" or something like that. I was able to look up my original P tire (maybe weight also) and cross reference it to the E tire and it specified a new pressure to run. That was about 45 psi I think. So all things being the same, just going from P to E I needed to run at the higher pressure. That's one way to do it. Its all buried in this Forum somewhere, maybe I can find it.
This was part of it I think
https://www.expeditionforum.com/threads/tire-pressure-sensor.34019/#post-281108
I've run LT tires on my 2003 @45 for a couple years and they are wearing about right so far.
Its interesting nobody commented on that pic I posted , how it looks.
07navi
Mt.Shasta California
Here we go again.
I agree with all that and most people don't realize the E rated tires are at their strongest at their max rated psi. C rated are probably best for these Expys in here and they hold 50 psi max. Much better than a flimsy passenger p rated tire.
TobyU
Ohio
Yes or at least an extra load pick up style tire.
Those kind of look like my dads BF Goodrich K02’s he just had put in his F-250.
762mm
Quebec, Canada
Not co
True. This is why I never turn my wheels when the truck is not moving, as the resistance of a static wheel destroys steering components ten-fold.
"Never", unless it's some sort of a situation where I absolutely need to... of course.
Aa for correct pressures, they should be printed on the door sticker. To be honest, I don't remember what mine says. I got by looks and experience, so my 35 PSI might indeed be kind of low for a heavier truck (I'm still used to what I'd put in my old Explorer, lol).
TobyU
Ohio
Yes but those pressures put inside the door are only correct if you have the same load range tires that came with the vehicle from the factory. Anytime you change load range those pressures are no longer applicable.
