Sadler
01 expy 4.6 After driving for a bit and having truck at operating temp the idle will start dipping bellow 500 then up to 700 then a few seconds later below 500 and up again. It only happens when I come to a stop at a light or sign. You can see and hear the rpms dip as soon as the truck is about to stop. Doesnt happen in park. Its very rhythmic meaning i can almost count to when its gona surge again. Truck runs great otherwise except for an occaisonal light tapping sound which i think is just sticky lifters and engine ping occasionaly under load which i swear i get only after using hess gasoline.
-I have replaced the oem pcv in it with motorcraft pcv
-replaced the pcv gromet and the assembly hose including upper and lower elbows
-replaced IAC with oem from pepboys, returned it after a few days because there was no difference. (maybe motorcraft iac woulda worked?)
-cleaned TB
-cleaned MAF
-cleaned air filter
-seafoam..very little smoke
-tried cleaning EGR but couldnt get it off, ran intake cleaner through the top of it.
-power steering flush with lucas fluid
-one way brake booster check valve replaced
-techron
-marvel mystery oil via tank
-lucas tune up crap via tank
-oem coil packs and oem plugs done by my mechanic x8 cylinders
Any help would be appreciated because its driving me nuts, and of course when I go to my mechanic it doesnt do it. I am going for back surgery soon and am trying to get everything perfect on this truck over winter when i cant touch it. Thanks guys.
-cleaned TB
-cleaned MAF
-cleaned air filter
-techron
