Hi everyone!
Let me jump in with my problem.
My Expy is having heating problems. The heat is "ok" when its 50-60 out but as the temps drop, the heat is less and less warm. Get to single digits and its barely warm though gauge in right in the middle where it should be.
This has been going on for 2 years. (I keep wanting to get it fixed but trying to DIY it)
I noticed my upper radiator hose is not pressurizing when the truck has been running for a long time....I can pinch it closed....
It doesn't overheat....I took a 5k mile trip last summer with no problems.
I replaced the tstat just because...no change.
I'm thinking its the reservoir cap....not maintaining pressure??
Thanks in advance for your responses!!
--Edit--
I replaced the rez cap today and ill see what happens.
I drove to the auto parts store and back (30 min) and when I got home I felt the upper rad hose.....it felt cold and as if nothing inside...no pressure.
I took off the rez cap and nothing... no pressure.
hoses to and from core were nice and warm... not hot....both felt the same.
Fluid in rez was a little low....but fluid was in there..... I added 1 gal 50/50 AF and water.
I have searched the forum and cannot find anything with my symptoms......
--Edit--
