03-06 strutmasters conversion
B
Blwnl36
Jackson,NJ
i know alot of people have done it. im hopeing someone who did will pm me. loking for info on disabling the message on the dashboard.
SkyJumper
SW Florida
All you need is a schematic of the onboard air-ride control box harness. All you need to do is pull one wire out of the harness plug that plugs into the control box. The pin number or wire color I do not know but I am sure it is available thru google or here.
Had to do the same very thing to my Mark VIII when I lowered and converted it with the Strut-Master kit.
SkyJumper
SW Florida
Yes really, the onboard msg center will be disabled if you locate the single wire in the air ride control box. Once you locate that wire, then pull it out of the pigtail, and plug the harness back in. And then the signal for the air ride will be disabled. I just can not tell you on this application what the wire number and color is. But if you use Google search and query it and or call Strut-Masters up, they may be able to tell you. If the answer is on this site, Google will lead to the thread on here also. Most times with forum sites, the Google search is much better in being able to locate the thread for you than that of the site search function. Forum search uses words search and gives you alot of garbage that leads you nowhere, but search Google and it will define and locate more efficiently for you.
B
Blwnl36
Jackson,NJ
Ive called Strutmaster and they wont tell me the info unless youve purchased a kit from them. I purchased my kit from suncore. suncore wants you to leave the level sensors and air solinoids plugged in. Now whos says they go bad your still gona get that message? Ill check google and see if anything comes up.
B
Blwnl36
Jackson,NJ
ive searched google for an hour.....nothing. Does anybody have a link for a wiring diagram for the air suspension?
SkyJumper
SW Florida
That is correct, you do not have to unplug anything nor anything else if you do not want to, but to disable the msg center for the air ride only as stated before, you need to know what color code and wire number in the pig tail that plugs into the control unit, and pull it out or cut it.
B
Blwnl36
Jackson,NJ
Thank you. I cant find anything. I know the module is under the kick panel on the drivers side. Any help as far as wires goes will be greatly appreicated.
houseopain
NORTH CAROLINA
just had my conversion done and yes, i have check air suspension msg and I have tire sensor fault msg, it's been doing that for a couple of years now.
SkyJumper
SW Florida
I got this info from Suncore Industries on how to disarm the air ride message center. Hope this helps.
How To Disarm The Warning Air Suspension Light in Ford Expedition and Lincoln Navigator 1997-2002
