onetirefire
Hello,
I bought a 2004 EB 5.4 4x4 almost a year ago with 58k miles. Now its just over 65k. I like driving it. Comfortable and tows the boat like a dream, Barely know its there.
For the last few weeks, it has been making a noise from the front end above 50 mph. At least thats when I can make it out. It gets louder with higher speed. You can feel a small vibration in the steering wheel. I don't like running it with this noise, but I have had the axle out of my mustang for a rebuild which should be wrapped up tonight. Hoping to get after this noise soon when I can leave it parked. I haven't even gotten under it yet.
As far as troubleshooting: Engaging AWD or 4wd does not impact the noise, throttle application or removal does not affect the noise, shifting to neutral or out of O/D does not affect the noise, steering side to side does not impact noise. It is vehicle speed dependent.
Its either the front axle or wheel bearings I am thinking.
Any thoughts?
I was trying to decide next steps to troubleshoot. Don't want to just throw parts at it. I was thinking about disconnecting the front driveshaft between the xfer case and the front diff.
Will that stop the front diff from turning and tell me if the issue is a wheel bearing?
I was also wondering, could I take out the half shafts and drive shafts and completely isolate the axle and wheel hubs? My buddy who drives a chevy said that large nut that holds the half shaft into the hub preloads the wheel bearings and I could not drive without the bearings preloaded.
A penny for your thoughts.
Thanks
Any thoughts?
Thanks
