04 Squeaky Half Shaft Boot
rwing21
Louisville
Good afternoon,
This morning while going through a drive thru, I noticed a squeaking noise on the front driver side. I got home and pulled a tire and noticed the half shaft boot furthest back is squeaking. I sprayed the outside of the boot with some silicone lube with no change. On jack stands, the noise went away for a bit then came back. Very strange.
See the video of the noise here: https://www.youtube.com/watch?v=vwJqZh05CD8&feature=youtu.be
The boot looks good, no visible cracks etc. Advice?
Thanks!
R
rwing21
Louisville
have to look when i get off...youtube doesnt work at work
Thanks!
After watching the video on Youtube, I noticed that it doesn't sound the same way it does live. On the video, it sounds like it is coming from the front gear box but it is not. Keep in mind, that the sound does randomly go away.
R
rwing21
Louisville
sorry bruh...no clue
No problem. Thanks for listening. Very strange. I have found some other threads online indicating that this is the first sign that the boot is in it's early failure stage.
I am going to drop it by the transmission shop one day next week and see what they say.
R
rwing21
Louisville
The transmission shop that I have used in the past is closed for the holidays. Will take it in next week.
montecarlo31
Have you lost any grease out of the CV? I'd bet it is the joint inside the boot squeaking because it has gone dry.
